STT turbo kitt, on OM616 in a w115 - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 08-31-2011, 04:33 AM Thread Starter
Date registered: Aug 2011
Vehicle: Diesels om616 -> om606
Quoted: 55 Post(s)
got a w115 from 1976, with a om616 engine (240d from the w123)
changing to a rearaxel with 1:2.65 the car is going to be a bit tired.
so i also ordered a almost new STT-turbo kitt with a modified Intercooler
(the kitt still got the stickers on it)
what changes do i need to make to the engine?
NA valves and Oilsquirters on the Pistons where available on the om616 from India, and some of the 617 if im not misstaken, but are they needed?
if i have a low preasure and a good IC, will the car last?
not going to preasure it with full throtle, i just want to have a realy sweet rpm at 60mph (about 1500-2000rpm) with that extra power you need to pass other cars.
RSOCUstin likes this.
swampmonkey is offline
post #2 of 2 (permalink) Old 12-29-2012, 03:06 PM Thread Starter
Quoted: 55 Post(s)
can tell you, 240d 72hp with 2.65 diff was a bit tired, moved down to 195-65r14 to make it work, changed to a 3.07 drive and it worked great, am still looking for a fifth gear when coming from a newer car.
no problem sticking to the trafic tempo, and with some planing the overtakes is no problem either, about the same as with the stock 3.69 finaldrive.
about 35mpg mixed driving, and sweet rpms.
still no turbo thou.
and the turbokitted 300d with a 2.65 axle needs a fifth gear to. people saying that the car will be undrivable and extremely slow is wrong.
OM616 Overhaul mrspaz W123 E,CE,D,CD,TD,TE Class 66 07-30-2013 07:57 AM
W115 or W123 300D modifications manual transmission (5 or 4 speed), turbo, etc w123fanman W123 E,CE,D,CD,TD,TE Class 0 06-25-2011 09:13 PM
Friend needs help. Looking for om616 or possible 617.95x Atlanta winmutt W123 E,CE,D,CD,TD,TE Class 0 05-24-2011 02:26 PM
Eartha Kitt... 420 SE Off-Topic 8 12-26-2008 12:14 PM
OT: where is KITT? Crypto W163 M-Class 2 03-14-2003 11:55 AM
