rear suspension adjustment - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 08-30-2011, 10:50 PM Thread Starter
Date registered: Jan 2011
Vehicle: '73 280 (114)
i just replaced all 4 shocks with Bilsteins and the ride was marvelously improved. I then swapped the rear springs and rubber mounts because the rear was squatting down and again the ride is so much better. Unfortunately, the rear is now much taller and the camber is off on the rear wheels now and I cannot find an adjustment procedure for this. I am fine to take it to a shop, but I am a guy who likes to know what the procedure is and what is involved. Anyone know ow to adjust the rear end camber on a 73 straight 280?
I'm doing the front springs this weekend and taking it to my shop for an alignment et al and I would love to know what's up with the rear before I get there.
rsizemore is offline
post #2 of 8 (permalink) Old 08-31-2011, 04:19 AM
Date registered: Aug 2009
Quoted: 53 Post(s)
There's no camber adjustment for the rear unless you have the after market trailing arm eccentric bushings.
The odds are you installed a larger spring pad. They come in 2 or 3 different thicknesses.
Mike D is online now
post #3 of 8 (permalink) Old 08-31-2011, 07:04 AM Thread Starter
Thanks Mike. Indeed I did add a larger pad. I may have misread the chart, but it looked like she needed 19mm pads although the units I removed looked thinner than any I found at parts stores. Hmmm.
post #4 of 8 (permalink) Old 08-31-2011, 10:24 AM
Date registered: Feb 2010
Vehicle: 1968 250SE S-Class. 1988 560SEC S-Class Widebody
Quoted: 39 Post(s)
I recently bought a full new set of rubbers from mercedes - I think they were listed in only 1 size though, or maybe they only supply 1 size now. for the forums reference they were pricey at nearly $200 for the full set of 6 rubbers (i think its top + bottom in rear and just bottoms in front or something like that)
Mine are pretty far deteriorated so it was neccessary, when shifting into reverse it used to squat down in rear and more so on left side
D&WCali is offline
post #5 of 8 (permalink) Old 08-31-2011, 04:28 PM
Quoted: 53 Post(s)
I've got a couple of sets from misc. W114's. If you still have your old ones, measure the thickness and maybe we can come up with a thickness between the old ones and the 19 mm's you installed.
Have you checked with AZautohaus (spelling is probably wrong)? They're in your neck of the woods.
The pads raise the height apx. TWICE their thickness (geometry doncha' know) so a 19 mm (3/4") pad will raise the rear 38 mm (1.5").
post #6 of 8 (permalink) Old 09-01-2011, 08:24 AM Thread Starter
Mike D,
Great as always. AutohausAZ is only 2 blocks from my business, but they will not allow walk-ins, so they get treated like any other online merchant. I did order the smaller pads from mercedesparts. They were only $4 and $7 D&WCali, so I really hope you didn't pat $200 for them.
post #7 of 8 (permalink) Old 09-01-2011, 11:02 AM
Quoted: 39 Post(s)
Originally Posted by rsizemore View Post
Mike D,
looks like for my w108 they are $50 per side for the rears on autohausaz (i paid $55 per side from dealer after discount)
front are not available on autohausaz and i havent found them elsewhere yet... so maybe I will hold onto these ones... hhhhhhmmmmm
D&WCali is offline
post #8 of 8 (permalink) Old 09-01-2011, 03:04 PM
Quoted: 53 Post(s)
There's a big difference between the hydro-pneumatic suspension on a W108 and the coil springs on the W114-115's so the price difference is understandable.
    R 129 SL600 suspension height adjustment Front Sporty R129 SL-Class 8 05-05-2013 09:58 AM
    Rear inside tire wear due to lack of rear camber adjustment jmerc6 R129 SL-Class 96 12-08-2011 07:40 PM
    Rear Suspension Height Adjustment? davegt W163 M-Class 6 03-06-2011 02:52 PM
    Rear suspension issue 2005 320CDi with Airmatic sports suspension. pjas1969 W211 E-Class 2 02-27-2011 05:52 AM
    300CD suspension drop, Camber adjustment plates? DPG W123 E,CE,D,CD,TD,TE Class 2 09-22-2010 12:24 AM
