w115 brake issue - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 08-26-2011, 04:40 AM Thread Starter
Date registered: Mar 2011
w115 brake issue
So I was cruising in my 76 300d w115 the other day and once it got up to running temp (~180), the brake warning indicator came on and it seemed like i lost brake boost...brake pedal would go almost all the way to the floor before lightly breaking....
fortunately i had just arrived to where i needed to be....
got back in the next day and everything was fine...until she got warm again...
any thoughts on where to look?
ian
ianfotheringham is offline
post #2 of 7 (permalink) Old 08-26-2011, 07:05 AM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 69 Post(s)
I'd look in the neighborhood of the vacuum pump.
flyboyike is offline
post #3 of 7 (permalink) Old 08-26-2011, 10:54 AM Thread Starter
Hey - i don't have a vacuum gauge - but i pulled off the vacuum supply line to the brake booster and it was sucking enough air to hold it against my finger pretty well.....and that wouldnt explain the light staying on...
The brake fluid level is right where it should be....and when braking really hard there is no pull to either side...as a pressure difference can also cause the light to stay on...right?
or is a pressure difference between the front and back brakes? how to troubleshoot?!
thanks!
post #4 of 7 (permalink) Old 08-26-2011, 10:28 PM
Date registered: Sep 2008
Vehicle: 1975 450SL
Quoted: 15 Post(s)
Sounds like the booster has gone out on you. Although, how long since you've gotten the brake fluid changed and the system bled?
RadioTek is offline
post #5 of 7 (permalink) Old 08-26-2011, 10:50 PM
Mercedes mechanic's Avatar
Vehicle: Timeship, see you yesterday, but you already knew that.
If the booster went out the pedal wold be extremely hard to push, not easy.
The master cyl has gone out on you. To test this theory, pump the pedal 50 times, I bet before you get to 50, it will act the same as if it was warm. No brake pressure.
Top five reasons I posted in your topic:
1. You're talking about god, there has never been any god of any kind. EVER!
2. I just have a general dislike of you.
3. I am trying to tell you how to fix your Mercedes and you are not listening.
4. I'm flirting with Jody.
5. You're just to dumb to own a Mercedes, and should go buy a Honda.
Mercedes mechanic is offline
post #6 of 7 (permalink) Old 08-27-2011, 09:36 AM Thread Starter
Does anyone out there know what would happen if i replaced the MC that is on there (this one has the electronic sensor) with one that does not have the sensor?
Both models were apparently used in 76 300D's....but the one without the sensor is practically free - while the one with the sensor is 200$+....
post #7 of 7 (permalink) Old 08-28-2011, 06:31 PM
Date registered: Jun 2006
Vehicle: 1981 300CD, 1973 280C
Yours with the sensor is what triggered the early warning red light. The early style without the sensor will (cannt) not give you a warning. No other difference.
carnut1 is offline
W115 1974 240D Brake Lights not working pickpaul Vintage Mercedes-Benz 5 03-22-2010 11:13 PM
W115 220D Brake DIY/Tips chemmunist Vintage Mercedes-Benz 3 11-30-2009 06:49 PM
W115 Seatbelt issue madtag Vintage Mercedes-Benz 1 03-26-2007 10:50 AM
Fuel issue in 75 250D w115 Dr Evil Vintage Mercedes-Benz 1 10-22-2006 07:08 AM
need to buy: W115 front brake discs SakoTGrimes For Sale/Wanted/Trade/Giveaway 0 07-26-2006 06:15 PM
