W116 Chin Spoiler Etc. - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 08-23-2011, 06:50 AM Thread Starter
JABIV's Avatar
Date registered: Feb 2009
Vehicle: 1973 450 SE & SEL
Question W116 Chin Spoiler Etc.
Hi,
I'm in the process of restoring a 1973 450 SEL. I'm using some parts from a 73 450 SE that I inherited from my Grandparents who purchased it new from a dealer in St. Louis back in 73. When I had the body done on the SE back in 89 I had a chin spoiler installed. They riveted it to the body and covered the rivet heads with body filler. I removed the spoiler in hopes of putting it on the SEL. It's a little banged up from the years of wear and tear so I was wondering if they are still available?
Also, I need to remove the instrument cluster to get at the clock. Do I need to remove the entire dash board in order to do this or does it come undone from underneath the dash somehow? I'm using the SE parts car as a guinea pig, But would rather not monkey it apart.
Thanks,
J.B.
JABIV is offline
post #2 of 3 (permalink) Old 08-23-2011, 08:47 PM
kitchenrat's Avatar
Date registered: Feb 2006
Vehicle: 89 420sel, 83 volvo 244
the instrument cluster is a friction fit. using screwdrivers or picks, carefully pull it out far enough to take it in hand and pull toward you. unscrew the speedo cable, unplug the 2 electrical connectors and loosen the oil pressure tube with a 10mm wrench. when replacing the cluster it may not fit as well, but tape or weatherstrip can be used to tighten it up. good luck with the clock repair.
kitchenrat is offline
post #3 of 3 (permalink) Old 08-24-2011, 05:17 AM Thread Starter
JABIV's Avatar
Easy as pie?
Wow, that sounds almost too easy. I'll give it a try on the donor car first, that's where the working clock is.
While I've got your attention, does anyone know how to remove the ignition from the dash? I need to switch the ignition, door handles/locks and trunk lock from one car to the other. I've got it all done except for the ignition.
This is much easier on my old fords by the way...except for the instrument cluster that requires removing several screws.
Thanks for all your help.
JABIV is offline
Got me a chin spoiler finally. Nutz 4 Benz W116 S, SE, SEL, SD Class 11 10-01-2009 02:22 PM
Damaged AMG chin spoiler Hans380SEL W126 S,SE,SEC,SEL,SD,SDL Class 2 07-30-2008 08:24 AM
wtb: 1st gen SEC chin spoiler? 4-speed For Sale/Wanted/Trade/Giveaway 0 11-14-2006 07:06 AM
Chin Spoiler...(pic) Kevin Van Caster W140 S-Class 9 06-05-2006 07:55 AM
LOOKING FOR A CHIN SPOILER MBRIDER707 General Mercedes-Benz 0 08-03-2005 02:19 PM
