I need tips installing distributor when removed rotorposition on 280SEL 4,5 V8 1972 - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 08-21-2011, 01:18 PM Thread Starter
Date registered: Sep 2010
I have problems finding TDC (top-dead-centre) on 1. sylinder. I have engaged a remote controll between the relay on starter and + on battery. Removed 1. spark plug and feelt the compression generated with the thoumb. But its a bit difficult, even if I only touches the controll a short while, the wheel with the marks on removes 3-4 inches. So it maybe removes a bit after I have felt the cpmpression. I have found out when the car ran that the 0 degree mark on the crankshaft pulley is far away from the pointer when i put a timing light on 1.spark plug, so it must have been installed wrong. Is it much job to fix this?
The other method is pulling engine over over by a wrench with your arms. But I cant see the screw to put the cub key on. Does something have to be removed before doing this? It is very small space between the fan blades to put a cup key in to the screw on the crankshaft.
I hope someone see whats my problem.
280SEL4,5 is offline
    1972 280SEL 4,5 1972. Need new motor Wiring Harness and new throttle position sensor 280SEL4,5 Vintage Mercedes-Benz 3 05-31-2011 08:25 AM
    1972 280sel mprider Vintage Mercedes-Benz 2 11-04-2008 12:27 PM
    1972 280SE 4.5L car and 1972 280SEL 4.5L parts car for sale benzmeister_WI For Sale/Wanted/Trade/Giveaway 6 09-10-2007 04:38 AM
    1972 280sel 4.5 One Owner! CA car. Autobahnfahrer For Sale/Wanted/Trade/Giveaway 1 09-19-2006 08:08 AM
    Is this 280sel a 1972 or 1973? ldshull Vintage Mercedes-Benz 8 01-29-2006 07:18 PM
