W115 300D leak on torque converter - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 08-14-2011, 06:25 AM Thread Starter
Date registered: Aug 2011
I am new to the forum,but have a W115 300D from 76 since 8 years now. in the past, the problems i got, i could handle myself with common sense and the manual. this time I think i need some help from some specialists here on the forum.
the problem is that the car is loosing transmission fluid and i mean a lot. When i look under the car i see it leaking out from the torque converter. I checked the plug of the converter to see if its leaking from there, but thats good.
Any idea what the problem could be.
rr2266 is offline
    81 300D Torque Converter drain plug kstudhalter W123 E,CE,D,CD,TD,TE Class 8 05-04-2011 04:59 AM
    Torque Converter Seal Leak VR6MAN W126 S,SE,SEC,SEL,SD,SDL Class 3 10-24-2010 02:36 PM
    1981 300D -- torque converter drain bolt kmclarty W123 E,CE,D,CD,TD,TE Class 3 04-16-2010 09:08 PM
    1982 300D torque converter symptoms lxwlxw W123 E,CE,D,CD,TD,TE Class 1 01-19-2009 11:21 AM
    Transmission Leak at Torque Converter Housing Gasket lca13 W202 C-Class 1 03-29-2008 05:28 PM
