'71 250c New Owner - Where to get parts? - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 08-07-2011, 08:27 PM Thread Starter
Date registered: Aug 2011
Howdy All - I just got a '71 W114 automatic that I'm planning to restore. The first order of business is a carburetor rebuild, as the engine runs fine at all speeds except idle. Can anyone recommend a good place to get carburetor kits? Online is probably a given, but I'm in Fort Worth, Texas, in case there are any local sources. Thanks. -Glenn.
GlennG is offline
post #2 of 9 (permalink) Old 08-07-2011, 11:23 PM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 102 Post(s)
Try local parts stores - you'd be surprised what's still available through Napa, O'Reilly's, Kraegan and more.
Do a general search on this forum too - lots of old posts on parts
Grubeguy is offline
post #3 of 9 (permalink) Old 08-08-2011, 05:45 AM
DanW114's Avatar
Date registered: Jan 2011
Goodluck with the restore - W114 are the last of the classic mercs in my eyes.
Check out my build up of my w114 sedan.
http://www.benzworld.org/forums/vint...owrider-9.html
DanW114 is offline
post #4 of 9 (permalink) Old 08-08-2011, 05:48 AM
DanW114's Avatar
Also post some pics of the new girl so we can see
DanW114 is offline
post #5 of 9 (permalink) Old 08-08-2011, 09:39 AM
Date registered: Nov 2008
Vehicle: 1981 300TD 310k--1966 230 165k--1970 280se 172k
Quoted: 36 Post(s)
Try this place:
Mike's Carburetor Parts
I couldn't believe it was this easy to find a rebuild kit for my old Solex's.
1981 300TD--310k miles
1970 280sel--172k miles
1966 230--162k miles
carpenterman is online now
post #6 of 9 (permalink) Old 08-08-2011, 12:07 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 712 Post(s)
One of my all-time favorite Mercedes -- an absolutely gorgeous car -- in most colors.
GeeS is offline
post #7 of 9 (permalink) Old 08-12-2011, 10:30 AM
Date registered: Mar 2011
Vehicle: 1971 250/8 sedan with 80 K miles. Driven only in Summer.
I purchased my 2 sets at the local M.B.dealer for under $40.00 each. Part #000 586 01 07.
do not forget to remove the center screw in the hole for the air cleaner housing. the most important jet is the tiny brass idling jet. you can see it in the middle section once the top section is off. It should have airflow through it.Good luck..
Over 75 is offline
post #8 of 9 (permalink) Old 08-13-2011, 09:47 PM Thread Starter
Work Begins . . .
Thanks for the suggestions, guys. Got kits and started work today. Just about got one carb cleaned up and ready to reassemble. Previous owner left a couple extra carbs in the trunk, so I got some spare parts. Funny thing, the two carbs on the car had different sized primary mouths, although the throats are the same. I'm gonna use one of the carbs from the trunk so both will be the same. No idea which is correct for the car, but choice was made by a cracked cover on one of the large-mouth carbs.
I really need a right inner fender and possibly the frame member it's attached to. Might need the front crossmember, too. Just mentioning in case anyone knows of such. Need to take a closer look at the crash damage, but right now just want to get the car mobile enough to drive it around back to the restoration shed. -G.
GlennG is offline
post #9 of 9 (permalink) Old 08-18-2011, 01:06 AM
50$84sd's Avatar
Date registered: Oct 2009
Vehicle: 1965 220se w111 *******1984 300sd w126 *******1991 350sd w126
Thumbs up
Post some pics so we can check out your prize. Later.
50$84sd is offline
    1972 250c parts or restore comrade904 For Sale/Wanted/Trade/Giveaway 2 07-28-2011 05:22 PM
    Looking for 1970 250C W114 Parts joshes For Sale/Wanted/Trade/Giveaway 3 07-19-2011 12:06 PM
    1970 250C Parts needed rudedude Vintage Mercedes-Benz 5 10-26-2010 08:07 PM
    New owner of 1972 250c /W114... need parts & tips nduhig Vintage Mercedes-Benz 7 12-27-2009 10:00 AM
    The 3rd owner this year of a '72 250c griff199 General Mercedes-Benz 0 09-28-2008 04:57 AM
