What can I use to seal my Tail Lights? - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 08-01-2011, 12:17 PM Thread Starter
Date registered: Feb 2011
Vehicle: 1973 220D
I have a 1973 220D - although I don’t think that matters.
My problem is my tail light is filling with water because the seal (the gasket between the lens and the tail light housing) is completely shot. The old gasket looked much like a white O ring - it had no particular shape. It was about 25mm (1/8”) diameter and maybe slightly fatter when it was new and it still very pliable (just falling apart).
The lens and the tail light housing look to be in pretty good shape (after I cleaned out the considerable crud that had collected in there) But I cannot find this gasket available anywhere. New lens or whole new tails light (housing and lens) are available for a few hundred $$
Does anyone have a source for the original gasket - or even a generic product I could use - like a large O ring - probably softer and more pliable than traditional O ring.
Has anyone used a silicone sealant product? (like from a tube) Is there one that will not stick (we want to keep the water out - we DO NOT want to glue the lens on.
Thanks very much,
frankflynn is offline
post #2 of 5 (permalink) Old 08-01-2011, 12:44 PM
Date registered: Nov 2008
Vehicle: 1981 300TD 310k--1966 230 165k--1970 280se 172k
Quoted: 33 Post(s)
Try a thin closed cell weatherstripping (black rubber) with an adhesive backing from Home Depot or Lowes. Put the seam/joint toward the bottom.
I'd also be tempted to try some rope caulk, but I'm not sure how it would hold up with the heat.
1981 300TD--310k miles
1970 280sel--172k miles
1966 230--162k miles
carpenterman is offline
post #3 of 5 (permalink) Old 08-02-2011, 12:38 AM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 95 Post(s)
Try the thin foam weatherstripping, with the seam at the bottom. It's what I use on my 108
Grubeguy is offline
post #4 of 5 (permalink) Old 08-03-2011, 12:14 PM Thread Starter
Vehicle: 1973 220D
Foam weatherstripping seemed to work
I did the foam weather stripping.
I was also tempted by the caulk rope - I think it would have worked fine but would have been kind of gooey or stopped working after I had opened the light a couple of times. (maybe not)
The foam has some structural strength so I could pull it out and put fresh stuff in in years to come. (or so I think now).
I had to cut it down to the correct width to get it to fit but it does seem to seal quite well. For under $3 too!
post #5 of 5 (permalink) Old 08-03-2011, 09:06 PM
wbain's Avatar
Date registered: Dec 2003
Try drilling a small hole where the water collects.
wbain is offline
    Just replaced 04 tail lights with SL55 tail lights taickieu R230 SL-Class 7 11-14-2010 03:50 PM
    Head lights low beam and park lights and tail lights kojo W202 C-Class 5 09-14-2010 06:03 PM
    Senors - Parking Lights, Head Lights, Tail Lights Erotic1 C215 CL-Class 1 03-16-2009 08:39 PM
    Any interest in trading W123 US tail lights for Euro tail lights? Dr.Grillz W123 E,CE,D,CD,TD,TE Class 4 05-01-2007 04:45 AM
    Those tail lights for a w220 are not unique at all comparing to these S-Class Tail Lights Guest (MBNZ) W220 S-Class 7 06-14-2002 08:17 PM
