'76 450 SLC - Fast Idle when Cold - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 07-29-2011, 09:18 PM Thread Starter
Date registered: Jul 2011
Vehicle: 1976 450 SLC
Greetings, seeking suggestions on my first 450 and still learning it's traits. When cold the engine starts within 5 seconds but runs a fast idle. Once warm, the car is a bit tricky to start and does not run a fast idle. My guess is a vacuum issue but would like to hear the thoughts of others. Thanks!
VocoTexas is offline
post #2 of 4 (permalink) Old 08-04-2011, 06:42 AM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 67 Post(s)
Cold start valve checked?
flyboyike is offline
post #3 of 4 (permalink) Old 08-06-2011, 09:44 AM
Date registered: May 2011
Vehicle: 1979 450SL
I have 79 450SL with the same issue. When cold it starts right up but idles high. After warm it takes 4 or 5 times before it will start. So I'm interested in what you find.
rlajack1217 is offline
post #4 of 4 (permalink) Old 08-13-2011, 07:54 AM
rgrady's Avatar
Date registered: Feb 2010
Vehicle: 1977 450SL
I think both of your cars has the Bosch K-jetronic fuel injection.
The high idle is normal when cold to a point. The warm up regulator (WUR) idles the motor up during warm up to around 1200 to 1400 RPM. As the car warms up the WUR lets the idle go down. Lots of topics on this if you use the search function. Especially in the 107 forum.
The hard start after the engine is warm is typically caused by a bad fuel accumulator and/or check valve on the fuel pump. This is located on the passenger side, US cars, right behind the rear axle. Easy to change but costs around $100.00. AutohauseAZ has them listed at $97.95
Luv them Texas Longhorns
1977 450SL
rgrady is offline
    Fast idle from cold is high 320 CDI SlacKeR W164 M-Class 5 05-04-2014 12:23 AM
    Hard start (esp. when Cold), low idle-- Idle Control Valve? Erwin8r W124 E,CE,D,TD Class 17 08-31-2012 09:22 AM
    86 560 SEL fast idle saphiro W126 S,SE,SEC,SEL,SD,SDL Class 6 01-31-2011 10:09 PM
    Low idle, rough idle, stalling, hot and cold start solved: E320/300 rvenerac W124 E,CE,D,TD Class 10 03-22-2010 11:28 PM
    Fast Idle Big D W126 S,SE,SEC,SEL,SD,SDL Class 4 08-06-2004 04:25 PM
