low speed manual downshift inop - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 07-27-2011, 09:29 AM Thread Starter
Date registered: Jul 2011
Vehicle: 81 450 slc
I am driving a 71´ 280 se and it has only one small problem with downshifting. Above 40mph all manual downshifts work correctly, below 40 mph it wont downshift at all. It WILL downshift correctly with slight accelerator pressure at any speed. The problem is only on a decending road, no accelerator pressure shifting into 2 second for engine brake effect. If I tap the pedal, I get second gear and proper engine brake but no shift occurs otherwise. I have adjusted throttle control linkage to the tranny, I have replaced the copper gaskets in the vacuum line also. I have adjusted the modulator 3/4 turn clockwise (no gauge) and no result. I removed the modulator and confirmed free moving diaphram and slide pin. Any way to narrow this down for me? Trying to find the right oil pressure gauge but no luck so far. Thanks for any heads ups!
kevinpiersonandson is offline
    '85 gauges inop/turbo inop cmarknow General Mercedes-Benz 0 11-21-2010 09:16 PM
    need 722.500 5 speed auto or 5 speed manual ken garchow R129 SL-Class 4 04-16-2008 07:28 PM
    Those planning on SLK350 w/7-speed auto, why not a 6-speed manual? PhoenixS4-SLK55 R171 SLK-Class 3 02-11-2004 08:21 AM
    Manual 6-Speed SEC Jim Rothrock W126 S,SE,SEC,SEL,SD,SDL Class 7 01-02-2004 01:54 AM
    Violent downshift to 1'st gear at low speed deceleration (99 320) j keto C208/A208 CLK-Class 1 04-28-2003 07:52 PM
