Parts Interchange '72 220 to '73+ 230 - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 07-22-2011, 10:26 AM Thread Starter
Premium Member
Date registered: Sep 2006
Vehicle: 1989 560SEC AMG Euro / 1997 S500 / 1991 500 SL Euro / 1991 500 SL Japan
Quoted: 9 Post(s)
Premium Member
Hey all,
How many of the engine/driveline/mechanical parts wil swap from a 1973 (or newer, not sure on the year) 230 sedan into my '72 220? They are both packing the M115 and are both automatics. Do major mechanical differences exist between the 220 and 230 engines?
I know the bumpers are out as they are the big nasty diving board style, so I assume this means front fenders, grille and hood as well?
Any hints would be appreciated!
- Steve
1989 560SEC AMG Euro / 1990 300SE Euro / 1991 500SL Japan / 1997 S500 USA
cyberdyne is offline
post #2 of 9 (permalink) Old 07-23-2011, 06:41 AM
Date registered: Aug 2009
Quoted: 59 Post(s)
Mechanically-wise they are almost identical. If the one has the "parking bench" bumpers then it is a '74 up. Pretty much everything body-wise with the exceptions of hood, grill, and minor trim pieces will interchange. The fenders will fit but you'll need to do a bit of fill where the original bumpers mounted on the '74.
The doors will fit but they eliminated the "wing" window.
Mike D is online now
post #3 of 9 (permalink) Old 07-24-2011, 11:03 PM
unaffiliated's Avatar
Date registered: Mar 2011
Vehicle: 1993 400E, 1993 300TE Wagon, 1977 Euro 6.9, 1967 230S IMA Universal Wagon, 100 or so MB Parts Cars.
The fenders are different too. Basically the entire front end sheet metal is different between a W115/8 (1968-1973 Gen.I if you will) and a W115/4 (1974-1976 Gen.II). Same is true for the W114 body. They changed everything, hood, fenders, grille, valance, core support and bumpers. The only thing on the front clip that will interchange is the headlights. Even they had different versions but can be retrofitted.
Autos
1993 400E
1993 300TE Wagon
1985 300D Turbodiesel 688,000 miles on original engine/trans
1979 300SD
1977 Euro 6.9
You cannot change your future without disturbing your present.
It looks a whole lot more like it does today than it did yesterday?
unaffiliated is offline
post #4 of 9 (permalink) Old 07-25-2011, 06:47 PM
Quoted: 59 Post(s)
Quite right. I forgot to mention if you changed the fenders you need to use the entire front clip from the donor. You can use a '74 front clip on a '73 and older but you have to use all of the front clip. Radiator mount and all.
post #5 of 9 (permalink) Old 07-27-2011, 11:09 AM Thread Starter
Premium Member
Quoted: 9 Post(s)
Premium Member
Awesome! Thanks for the help guys!
I am going to pick this car up strictly as a parts car, strip out what I need and scrap the car. The body is pretty ratty but the interior is mint and the car is a solid runner.
With the rad support being different, does this mean the radiator will not interchange?
- Steve
post #6 of 9 (permalink) Old 07-27-2011, 04:55 PM
Quoted: 59 Post(s)
The radiators will interchange but they are mounted further back on the '74 which why you have to change the mount.
post #7 of 9 (permalink) Old 07-27-2011, 06:06 PM Thread Starter
Premium Member
Quoted: 9 Post(s)
Premium Member
Sorry if this is a stupid question, but I am pulling parts from the newer car to the older one....so do I need to update the mount to fit the new radiator?
- Steve
post #8 of 9 (permalink) Old 07-28-2011, 05:36 PM
Quoted: 59 Post(s)
Only if you are using the front clip from the newer car. The radiator should be a straight change over using the older car's hoses.
post #9 of 9 (permalink) Old 07-28-2011, 10:25 PM Thread Starter
Premium Member
Quoted: 9 Post(s)
Premium Member
Awesome! Thanks for the info. It is much appreciated.
I am trying to strip the newer one down for as many interchangeable spare parts as I can get off it before scrapping it.
- Steve
    SEC to other 126 interchange? Parts in common? renaissance_warrior W126 S,SE,SEC,SEL,SD,SDL Class 12 06-02-2009 12:16 PM
    PSE pump parts interchange themotorpool W140 S-Class 6 05-08-2009 05:41 PM
    Interchange motor parts fras W126 S,SE,SEC,SEL,SD,SDL Class 2 01-16-2008 07:51 AM
    vin # / parts interchange tmoger Unimog 2 03-03-2006 06:40 AM
    Parts Interchange liltommy G-Class 13 11-05-2004 05:37 PM
