Looking at a 1967 200d. What should I expect? - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 07-20-2011, 03:54 PM Thread Starter
bunnytrucker's Avatar
Date registered: Jun 2011
Vehicle: 63 Unimog ex-swiss 404, 59 220S W111#000925 from Ethiopia, 92 VW Corrado SLC
I am looking at getting a cheap little diesel for the wife to putt around in. Our audi s4 just broke a timing belt so its done for. We are ready to downsize a bit and go back to something simple, old and not as expensive as an s4 to maintain and fix.. Long story short, I'm looking at 190-200d's because I have always loved fin tails. What do I need to know? Anything I should look out for? These cars pretty bullet proof? I would like to be able to take it on road trips. Tell me what you guys think? I don't want to pick one up and realize I made a mistake.. I'm expecting gutless and slow
bunnytrucker is offline
post #2 of 4 (permalink) Old 07-20-2011, 08:11 PM
Date registered: Nov 2008
Vehicle: 1981 300TD 310k--1966 230 165k--1970 280se 172k
Quoted: 33 Post(s)
I'd reckon the most important thing to look for is rust, especially in the rockers and undercarriage. Check over the headlights and in the spare tire wells in the trunk. Door bottoms, too. Windshield seals may be deteriorated and cause leaks into the cab as well.
Jack up the front and wiggle the suspension at 12/6 o'clock to check the kingpins for play and at 9/3 o'clock for tie rods and general steering looseness.
See if the heater core is leaking or has been bypassed. Do a simple engine health test by loosening the oil cap while running and see if the cap dances around. Or better yet, get yourself a diesel compression tester and do a compression check. Black smoke out the pipe is OK (can usually be adjusted out), blue smoke is bad.
Brakes are front disc/rear drum. The rear shoes are no longer available so you would have to have them relined if they are shot. When were the rubber lines last replaced?
Most parts for the mechanics are readily available online or from the Classic Center. Trim and interior are harder to find and generally cost a bunch. Consider how well the car has been cared for. Are there maintenance records? If it's been neglected, you will spend a lot of time and money sorting things out. Better, IMO, to spend more upfront for a well-maintained finny, especially if you need it to be reliable.
That being said, the w110s are wonderful cars to have and drive.
P.S. Maybe Squiggle Dog will chime in. He's been all over his '68 200D.
1981 300TD--310k miles
1970 280sel--172k miles
1966 230--162k miles
carpenterman is offline
post #3 of 4 (permalink) Old 07-24-2011, 10:14 PM
unaffiliated's Avatar
Date registered: Mar 2011
Vehicle: 1993 400E, 1993 300TE Wagon, 1977 Euro 6.9, 1967 230S IMA Universal Wagon, 100 or so MB Parts Cars.
If you end up getting the car, I have 5 or 6 fin bodies for parts. One of them is even a 200D with a factory sliding roof, pretty rare indeed.
1993 400E
1993 300TE Wagon
1985 300D Turbodiesel 688,000 miles on original engine/trans
1979 300SD
1977 Euro 6.9
You cannot change your future without disturbing your present.
It looks a whole lot more like it does today than it did yesterday?
unaffiliated is offline
post #4 of 4 (permalink) Old 07-25-2011, 09:51 AM Thread Starter
So I ended up sticking with the w111 body but changed things up a bit.. I ended up getting a super clean OG low miles 59 220s euro spec out of so-cal. Was sent from the factory to a hospital in africa in 59 and shipped to california some time later probably late 60s. I could not resist those euro spec headlights! Now comes the adventure of driving it 1000 miles home.. Luckily only one pass at about 4500 feet.. Should be exciting! I will post some pics when I have some..
    200D Beverly Sharp Vintage Mercedes-Benz 2 05-18-2010 07:10 AM
    considering a 1967 Mercedes Benz 200d terracotta Vintage Mercedes-Benz 4 04-27-2010 08:56 AM
    200d F.S. redlinedave W123 E,CE,D,CD,TD,TE Class 13 09-03-2009 06:31 PM
    1967 200D Bendx Vintage Mercedes-Benz 1 10-21-2008 08:15 AM
    Will a 1979 240d bolt up to a 1967 200d? Dieselburn Audio & Telematics Forum 1 12-27-2006 10:02 AM
