300D-Getting rid of body rust.. - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 07-20-2011, 01:40 AM Thread Starter
Date registered: Dec 2009
Vehicle: 1976 300D
Quoted: 2 Post(s)
Send a message via Yahoo to amarbenj
i had my 300D repainted about a year and a half ago. but my big mistake was..i had not well supervised the painters...so there were rust again by this time..i wanted to do again the painting..any tip pls...so the rusting will be minimized..thanks.
amarbenj is offline
post #2 of 4 (permalink) Old 09-15-2011, 03:39 PM
tdoriot's Avatar
Date registered: Jul 2011
Vehicle: 1993 600SL, 1973 450 SL,1982 380SL,1998 SLK 230, 1968 Firebird, 2001 Dodge Ram 4x4,2005 Ford Escape
Quoted: 413 Post(s)
Cut it out and weld in new metal. Grind out what ever is not practical, use a rust conversion then a 2 part epoxy primer. Make sure everything is sealed, undercoated etc. Don't fall for the slop some POR 15 on rust and think it's all well and fine. If you cover it, it will return!
tdoriot is offline
post #3 of 4 (permalink) Old 09-16-2011, 12:11 AM
Date registered: Jun 2009
Body repair work was poorly done or not done at all. Have the car's body thoroughly checked for rust by an expert before you do any painting. There are many places where you don't see any rust on the surface but lots of it underneath unseen. These will create more problems later on and will not be fixed by simply painting over them.
ijiwaru is offline
post #4 of 4 (permalink) Old 09-18-2011, 01:30 AM
Dusty`NZ's Avatar
Date registered: Mar 2004
Vehicle: w115-240D, w115-300D, w201-190e (3), w123-300D w201-190d
After the visible rust is cut out and repaired properly , you must also spray the insides of the panels and pillars with a rust inhibiting wax/penetrant to help prevent further deterioration.
Just leaving the insides of the repaired panels dry (after all that welding) is asking for more corrosion.
'76 - 300D
'72 - 240D (noddy)
'40 Chev pickup
Dusty`NZ is offline
    WTB: '82-85 123 Body, No Rust jmcqueen For Sale/Wanted/Trade/Giveaway 3 07-22-2011 01:46 PM
    Rust! In the body, in the engine bay.... smokyburnout W123 E,CE,D,CD,TD,TE Class 6 03-22-2010 03:20 PM
    Body rust. Looking for help LNA W210 E-Class 23 09-10-2009 06:11 AM
    Rust traps on SEC body stevebower W126 S,SE,SEC,SEL,SD,SDL Class 4 10-15-2003 08:40 AM
    Body rust! sthu W163 M-Class 10 04-08-2003 06:59 AM
