W111 Water pump housing compatible replacements - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 07-19-2011, 03:36 AM Thread Starter
Date registered: Jul 2011
Vehicle: Mercedes 220SEb 1962
Post W111 Water pump housing compatible replacements
Any one knows if there are later versions (W124) of the water pump housing are compatible with the W111 (220SEb)?
It is hard to find any that are not corroded hence I'm looking for a compatible version...
Pauldg is offline
post #2 of 3 (permalink) Old 07-19-2011, 06:56 AM
Date registered: Nov 2008
Vehicle: 1981 300TD 310k--1966 230 165k--1970 280se 172k
Quoted: 33 Post(s)
My housing was buggered as well. Also the thermostat housing. Yes, they are hard to find.
As a last resort (or until I find a good replacement) I fixed them by carefully and slightly over-filling the pitting with JB Weld. Then a file and sandpaper to smooth. The rounded rims can be a real challenge to get right.
It worked for me, but of course it's a hillbilly solution.
1981 300TD--310k miles
1970 280sel--172k miles
1966 230--162k miles
carpenterman is offline
post #3 of 3 (permalink) Old 07-19-2011, 04:26 PM
I discovered that a 1/4-20 tap and bolt will replace the smaller metrics which hold the pump to the housing. JB weld works wonders.
Brian O
bostosh is offline
    water pump leak-what are good brand replacements... kickstarter69 R129 SL-Class 13 08-21-2012 01:28 AM
    WTB - 1959 Ponton 190, Water Pump Housing chenders246 For Sale/Wanted/Trade/Giveaway 0 03-13-2010 01:55 AM
    Should I replace Water Pump Housing russianwol W140 S-Class 6 10-12-2009 01:33 PM
    water pump housing bolt cashman W123 E,CE,D,CD,TD,TE Class 0 08-23-2006 09:45 PM
    last bolt on water pump housing TMN G-Class 3 10-29-2001 03:54 PM
