Replaced climate control servo still no heat? - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 07-16-2011, 09:50 PM Thread Starter
Date registered: Oct 2010
Vehicle: 1978 300D W123
Hey any info would help at this point!
I replaced my evil servo with a rebuilt aluminum body unit and a new amp behind the glovebox. Im not getting any heat from the 2 hoses on the backside of the servo? Almost like its not turning on.
I hear no humming from the servo when the ignition is on?
Where is the fuse for the servo?
My vents blow air from all settings just not hot
Once again guys thanks for any info
1978 300D W123
dirkfunk is offline
post #2 of 5 (permalink) Old 07-17-2011, 11:23 PM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 99 Post(s)
Have you flushed your system? Did you get heat before you replaced the servo?
Grubeguy is offline
post #3 of 5 (permalink) Old 07-18-2011, 02:03 PM Thread Starter
ive flushed the system, and no I did not have heat before the replacement.
After further probing I noticed hot water is getting to the Aux pump and not to the servo.
Can I just bypass the aux water pump? I live in San diego Ca so the weather is fine.
dirkfunk is offline
post #4 of 5 (permalink) Old 07-18-2011, 05:39 PM
Scoot's Avatar
Date registered: Oct 2002
Quoted: 118 Post(s)
You might want to mention what year/model car you have since that will make a big difference...
Scoot is offline
post #5 of 5 (permalink) Old 07-18-2011, 09:20 PM Thread Starter
1978 300D
dirkfunk is offline
    Heat Stuck on, Climate Control Panel/Climate Control Servo Problem? 123Doug W123 E,CE,D,CD,TD,TE Class 25 05-07-2016 12:40 AM
    Climate Control Servo Tip -- Check this before disassembling your servo! sshanky W116 S, SE, SEL, SD Class 2 02-17-2011 09:44 PM
    82 Climate control servo Bluedevils39 W123 E,CE,D,CD,TD,TE Class 4 03-18-2010 01:25 AM
    WTB: Non-working climate control servo tointexas For Sale/Wanted/Trade/Giveaway 0 12-11-2006 12:17 PM
    Climate Control Servo tointexas R/C107 SL/SLC Class 0 12-11-2006 12:14 PM
