Strange sound comes from w108 differential! - Page 2 - Mercedes-Benz Forum
post #11 of 12 (permalink) Old 07-17-2011, 10:22 PM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 95 Post(s)
If you're doing brake work, you might replace the wheel bearings at the same time. The sound *perhaps* could be wheel bearings...
Grubeguy is offline
post #12 of 12 (permalink) Old 07-18-2011, 01:56 PM Thread Starter
Date registered: Jun 2009
Vehicle: 280SE 3.5
Hi again,
Today I removed all brake calipers as dealing with brake maintenance.I had opportunity to check rear axle.I checked space by lifting each rear end individually to define where the sound comes from and also space at differential gears.As a result, from both sides(left and right) free play(to forward&reward) when 'P' is about 25 degrees roughly also during turn, sound exist('tak' once) and shaft does not turn.Is it normal such space?Space from both axle seems to be same.All in all, I will replace new barrel type bearings to both axle and replace all internal and external axle seals.But if the reason of this sound and space is Joint.That time, it will be very difficult to disassembly whole differential.
Any suggestions or recommendations?
Jazzenco is offline
    c240 4MATIC strange differential noise Dr. Power W203 C-Class 7 06-01-2012 01:32 PM
    Need W108 Firewall Pad & Sound Deadening Info MB6er Vintage Mercedes-Benz 8 01-15-2009 01:03 PM
    Rear Differential Oil for W108/9 Gustav Vintage Mercedes-Benz 4 01-15-2008 04:47 PM
    strange engine sound - together with strange smell under hood? quepao W163 M-Class 2 01-23-2006 08:31 AM
    Strange Noise; Need "Differential Diagnosis"... Daniel W. R170 SLK-Class 0 06-01-2005 02:18 AM
