all kinds of wrong - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 07-14-2011, 05:28 PM Thread Starter
Date registered: Jul 2011
all kinds of wrong
HI all, im working on a 1974 280. starts fine but when is under pressure it back fires all over the place. dont know if this is timing or bad wires which are kinda bad or what? also i have a couple of vacuum lines not hooked up. they are in the front driver side coming from right behind headlamp. colors are a green one and then there are 2 clear ones. anyone happen to have a vacuum diagram or something? any help is appreciated. thanks
Oh btw... this is my first post, little backround on the car... my grandma was taking care of some lady and she gave it to my grandma. odo reads 14,000 so thats pretty cool. just trying to get it running good.
71cruiser71 is offline
post #2 of 5 (permalink) Old 07-15-2011, 04:17 AM
Date registered: Oct 2010
The backfire could be a timing issue; timing problems will occur if the distributor advance or retard vacuum lines are not working properly. Do you have the two and three way switches mounted on the right side fender well? They are wired to activate at low and high RPMs and route vacuum. Good luck finding a vacuum diagram. I have been searching for months for one. I have researched on line and at the library and still no luck there. I keep hoping someone could take a picture of theirs and post it.
curtisl is offline
post #3 of 5 (permalink) Old 07-15-2011, 06:00 AM
Date registered: Mar 2011
Vehicle: 1966 W108 250S
Check/replace all ignition maintenance parts (rotor/cap, plugs, wires).
Check/replace aircleaner.
Check for vacuumleaks. Block off any vacuum connection on the engine that you're not using at this moment.
What fuel is your car running? Petrol/gasoline, or LPG/Propane?
Sjak is offline
post #4 of 5 (permalink) Old 07-15-2011, 06:33 AM
Date registered: Jul 2009
Vehicle: 1964 Mercedes 220Sb
From another Benz website: forum.w116.org - 280SE Vacuum Solenoid location, oscar
tgikal is offline
post #5 of 5 (permalink) Old 07-15-2011, 12:06 PM Thread Starter
ya im in the process of giving it a tune up, plugs cap rotor etc... plug wires are next...
@vacuum diagram, unfortunatly thats not specific enouph. im thinking abt just getting a chilton book...
ya it would be nice if i could find one in person! that way i could check it out. im in socal so if anyone has one around let me know
abt the timing i fiddled with it and nothing seems to be resolving it, even messed with fuel.
any other opinions? thanks all for help
    OT: Guess there are all kinds... cypress188 W201 190-Class 1 12-19-2008 06:07 PM
    99 SLK 230 ECU part #'s 7 kinds??? sealluke R170 SLK-Class 2 07-07-2008 07:59 AM
    Takes all kinds............ Jakarta Expat Off-Topic 0 05-16-2008 09:50 AM
    PSE, will other kinds work? MarkR170 R170 SLK-Class 2 05-19-2006 07:06 PM
    All kinds of winter problems Lanorac W123 E,CE,D,CD,TD,TE Class 6 12-30-2005 02:28 PM
