Can you bypass A/T neutral switch? - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 07-11-2011, 02:55 PM Thread Starter
Date registered: Jun 2011
Mine is acting up and I have to run the A/T shifter through the gears sometimes then it will start. The neutral switch is just so you don't try to start it in Drive or Reverse correct? I doubt I'm ever going to do that so i was wondering if it was possible to bypass the switch with some creative wiring.
I have a '74 280 (114)
thanks,
Scott
ScottNC is offline
post #2 of 5 (permalink) Old 07-11-2011, 11:39 PM
Date registered: Jul 2009
Vehicle: 1964 Mercedes 220Sb
You would have to follow the wire from your ignition going to the Neutral Safety Switch, cut it, cut the wire leaving the Neutral Safety Switch going to the starter solenoid, and tie them together, thus bypassing the switch.
Not really that hard if you can locate it.
It's basic function is to prevent the ignition switch from actuating the starter solenoid unless the transmission is in park or neutral, therefor tying the wire from the ignition switch to the wire for the starter solenoid effectively removes the switch from the circuit.
Maybe someone else can help you with wire colors...
...It shouldn't be too hard, the Neutral Safety switch is located on the driver's side of the transmission, there are 4 wires going to it (one ignition, one stater, "I'm guessing" one reverse lights positive, one ... some other purpose... dunno...), just measure which one gives +12V when the ignition is turned to start (2 people is great for this!) that is the ignition wire, and which wire goes to the starter (I would just tap each of them with a +12V wire until the starter actuated, not necessarily safe... but it will work, just make sure it's in park... lol), the only other thing the switch controls is reverse lights. I would cut the wires high so if you wanted to reconnect them later you still could and leave the plug in so the reverse lights and whatever else still have a chance of working...
BTW: You can buy new Safety Switches for around $50, just so you know whether it's worth it too you or not.
Last edited by tgikal; 07-12-2011 at 12:08 AM. Reason: Locations and Testing Prcedure
tgikal is offline
post #3 of 5 (permalink) Old 07-12-2011, 05:47 AM Thread Starter
Thanks, very helpful info. I usually work on jack stands but this sounds like a project I should head over to my friends house who has a lift.
ScottNC is offline
post #4 of 5 (permalink) Old 07-12-2011, 08:40 AM
Date registered: Jun 2006
Vehicle: 1981 300CD, 1973 280C
I would be more inclined to look for worn out shifter bushings, rather than a faulty safety switch. The switch could also be loose.
carnut1 is offline
post #5 of 5 (permalink) Old 07-12-2011, 09:29 AM Thread Starter
I hope to get under the car this weekend to check it out.
ScottNC is offline
    How to bypass neutral switch. canuckbird74 W126 S,SE,SEC,SEL,SD,SDL Class 29 07-26-2015 07:09 AM
    ASR Bypass switch install 400E thundercat90096 W124 E,CE,D,TD Class 27 12-27-2013 09:57 AM
    Bypass Neutral Safety Switch 420sel MarkyBluntz W126 S,SE,SEC,SEL,SD,SDL Class 4 02-02-2011 05:14 PM
    Neutral Safety Switch/Backup Light Switch SC Surfer W123 E,CE,D,CD,TD,TE Class 13 01-18-2008 01:45 PM
    Trunk screen switch bypass anyone? gstark R170 SLK-Class 4 04-02-2007 01:38 AM
