Do factory installed diesel injectors have heat shields? - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 07-11-2011, 02:44 PM Thread Starter
Date registered: Mar 2011
So im in the middle of my monark diesel nozzle swap...
1976 300d w115...617.910
I removed the injectors pretty easily - but it looks as though there were not any heat shields in place for the old ones - or maybe they are just jammed in real good? looks as though there is something there...just not sure what....heres a pic - let me know what you think...
ianfotheringham is offline
post #2 of 3 (permalink) Old 07-11-2011, 11:21 PM
Goodchild's Avatar
Date registered: Feb 2008
Vehicle: 1994 S500 LWB, 1970 220D, 1994 E320, 1992 JAGUAR XJ6
There should be some sort of heat shield there but it sure quite different from a replacement heat shield that would come with say "monark" injector nozzles. i believe when i did mine on my 70 it didn't look like it had heat shields either. use a paper clip or a long skinny screwdriver to carefully pry upwards through the hole and see if anything comes out. Post back and let us know
Goodchild is offline
post #3 of 3 (permalink) Old 07-12-2011, 01:41 AM
Govert70227's Avatar
Date registered: Oct 2009
Vehicle: 2000 VW Golf Variant
Quoted: 4 Post(s)
It might be an old small one, which looks like a top hat. On the picture below you can see one, screwed on a reverse thread to extract it.
Govert70227 is offline
    Help with Heat Shields, Please! 500MPL W126 S,SE,SEC,SEL,SD,SDL Class 18 11-20-2010 07:29 AM
    Heat Shields? angelo225544 W123 E,CE,D,CD,TD,TE Class 4 03-19-2010 07:54 PM
    Heat shields Rmac58 W123 E,CE,D,CD,TD,TE Class 4 08-07-2009 01:20 AM
    82 300TD 2 injector heat shields found installed in #1? Goldenvoice General Mercedes-Benz 1 04-21-2009 03:35 PM
    diesel injector heat shields p100 W126 S,SE,SEC,SEL,SD,SDL Class 3 10-29-2007 06:48 AM
