W108 help me bypass emisions relays - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 07-07-2011, 11:15 AM Thread Starter
Date registered: Oct 2010
I have queried this forum several times with no response. I am becoming desperate in my attempt to get my 1771 280 S running. I have lost my job and will need to use her as my daily driver.
Problem: will not idle below 1100 RPM
• Both zenith carbs have been professionally rebuilt
• Ignition upgraded to Hot Point 50K
• Fuel system flushed
• I have one idle solenoid that does not work but it has already had the end clipped off anyhow.
I do not know how the emission switches should be hooked up and I want to return the car to euro status. The instructions I read says to attach the rear carb to the dashpot but I do not have dash pots on my carbs.
curtisl is offline
    Failed emisions on 2007 e350 gwozhog W211 E-Class 4 03-07-2010 08:10 PM
    New W108 Owner...Source for W108 Door and Window Seals? LaterApex Vintage Mercedes-Benz 5 03-24-2008 12:51 PM
    Failed emisions inspection SIXX9 W140 S-Class 3 08-26-2007 08:18 PM
    bypass the bypass valve? SLKRoadster99 R170 SLK-Class 8 05-22-2005 11:26 PM
    Relays? els3 W126 S,SE,SEC,SEL,SD,SDL Class 0 08-28-2002 09:07 PM
