Battery size for w115 200D - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 07-04-2011, 05:04 PM Thread Starter
Date registered: Jun 2009
I need to replace the battery of my w115 200D. Some people have told me that I should put in a DIN88 size battery as that size has the extra juice to turn the heavier diesel engine. What is installed right now is a 3SM size battery. I don't know how that size translates internationally but here in the Philippines that is what is usually used in the older (10 yrs+) 2.0 liter and over Japanese models. Is there a recommended size/type for MB diesels? By the way, my W124 diesel has a DIN66. Thanks in advance.
ijiwaru is offline
post #2 of 3 (permalink) Old 07-05-2011, 01:46 AM
Govert70227's Avatar
Date registered: Oct 2009
Vehicle: 2000 VW Golf Variant
Quoted: 4 Post(s)
Originally I think the W115-200D was fitted with a 66 Ah battery, later it was 88 Ah. 88Ah will be fine, but if the temperature is always high (above 10 degrees Celcius/ 50 Fahrenheit) you could have a lower capacity battery too. The 88 Ah is a requirement for climates which have low temperatures, because at low temperatures battery capacity drops.
Diesel engines require a lot of current to start: pre-glowing and turning over a heavy and high-compression engine. That is why there is a large battery in a diesel engine compared to a petrol/gas engine.
Last edited by Govert70227; 07-05-2011 at 10:52 PM. Reason: correction: 65 Ah > 66 Ah
Govert70227 is offline
post #3 of 3 (permalink) Old 07-05-2011, 04:46 PM Thread Starter
Will probably try a DIN66 then instead of the much larger DIN88. Temperatures here average around 26 to 29C. Thanks for the help!
ijiwaru is offline
W124 200D engine in W115 Persson121 Vintage Mercedes-Benz 1 11-19-2010 01:39 AM
WTB: W115 200D/220D pre '72 in UK coupetom81 For Sale/Wanted/Trade/Giveaway 0 03-17-2010 04:05 AM
Wich type of battery clamp ? W115 Eirik 400 SE Vintage Mercedes-Benz 1 08-10-2009 11:22 AM
Correct battery for 1966 200D Fin Tail Jim Molloy Vintage Mercedes-Benz 1 04-20-2009 12:02 AM
W115 BATTERY BANANA Vintage Mercedes-Benz 0 12-10-2007 06:29 AM
