250 head vs. 280 head - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 06-27-2011, 02:12 PM Thread Starter
Date registered: Jun 2006
Vehicle: 2003 230 Kompressor, 1970 280SL, 1991 300SL, 1970 SEL Limo
Does anybody know the design difference between a 250 head and a 280 head. I'm looking at a car (250SE) that believe has the original block, but has a 280 head.
No big deal?
Michael
Michael C is offline
post #2 of 4 (permalink) Old 11-23-2011, 01:10 PM
Date registered: Jan 2009
Vehicle: 1970 280 sel, 1979 300sd, 1988 300sel
Quoted: 10 Post(s)
I have the opposite, 250 head on a w108 280 sel
xaliscomex is offline
post #3 of 4 (permalink) Old 11-25-2011, 08:51 AM
wbain's Avatar
Date registered: Dec 2003
The engine plate is above the oil filter. A 280 block will start with 130.9xx. The engine designs are similar only the displacement is different.
The block for a 250SE starts with 129, i.e. M129 and M130 for the 280SE.
wbain is offline
post #4 of 4 (permalink) Old 11-25-2011, 01:52 PM
Quoted: 10 Post(s)
My 250 head is on a w108 280 SEL "BODY" and my engine is a(n) m129.
129 980-12-028007 to be exact. I don't know why the original owners would have swapped a(n) m130 for a(n) m129. Could be because they were more popular and cheaper. I purchased the car without service records, big NO NO. I was new to MB classics when I purchased the car and later realized that the chassis data card was removed, the distributor did not belong to a 280 sel and then surprise surprise the engine and head did not belong to the 1970 280sel....One thing that i do notice is a small metal plate with rivets just below the engine number stamped on the engine. I can clearly see the m129 designation on the plate but all the rest of the numbers are very hard to see. My w108 currently runs rich and I just checked the cold start valve this morning with the ignition on(car off) and I noticed fuel coming out when i removed the 7mm bolt. I'm actually in search of a w126 300sdl but I've had no luck. I am also considering a w126 300sel. I also drive a 1979 300sd and I call this car a work horse. Very dependable car. Will be removing the electrical/ mechanical window regulators and will be converting to manual. I'm tired of removing and replacing these poorly designed parts.
    For Sale: Head lights and head light bezels(black) factoryKITTED G-Class 3 12-22-2010 10:49 AM
    S320 CDI Head restraint height/tilt switch missing its chrome head - how do I fix ??? bhartv W221 S-Class 9 05-31-2009 03:28 AM
    Need Torque specs for Head and head tightening sequence for C43 calebjude2004 W202 C36 AMG, C43 AMG 1 09-18-2008 08:55 PM
    PUTIN RIPS HILLARY: 'At a minimum, a head of state should have a head'... Jayhawk Off-Topic 7 02-15-2008 07:06 PM
    The seven best car videos - cutting edge technology goes head to head! firstmb Off-Topic 0 03-11-2006 08:58 PM
