W115 engine changing - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 06-22-2011, 07:53 AM Thread Starter
Date registered: Jun 2011
Vehicle: 1975 230.4 & 1995 E320
Send a message via MSN to mu.ani Send a message via Yahoo to mu.ani Send a message via Skype™ to mu.ani
Exclamation W115 engine changing
hello i'm new to this forum!
i have W115.017 230.4 1975, i want to change the engine to a 200 m111 from the c-class 1992-2000 what do you guys think!!
is it possible or not?
and when changing i'll change the transmission and the axial and (that shift between them that i don't know what it's called).
thanks in advance.
mu.ani is offline
post #2 of 3 (permalink) Old 06-26-2011, 09:07 PM
Date registered: Mar 2011
Vehicle: 1972 280 SEL 3.5 - RHD
Good luck with the engine swap,
it would pay to talk to someone local who does engine swaps,
just looking at the initial setup without knowing what the story is. You would need to sort out the setup of a wiring loom. and the same setup for the gearbox.
measure up axles / diff etc check mounts for both gbx and engine depending on power difference, look at brakes, which could include new master cylinder, discs and calipers, possibly have a play around with the steering too as it might require a bigger pump.
i dont know too much about mercedes electronics, however have done some time on BMW and know that there are certain things that must match up between engine and gearbox i.e signatures that can only be set at the factory or by a licensed technician.
anyways i hope that makes it a bit clearer (or not!)
best of luck.
brendan
brendannw is offline
post #3 of 3 (permalink) Old 06-27-2011, 01:26 PM Thread Starter
best of luck.
brendan
hello Brendan!!
thanks for reply
my mechanical said he needs to know if that engine can sit in the car and he knows what to do.
Mu.ani
mu.ani is offline
    w115 engine swap arthrdgls Vintage Mercedes-Benz 10 03-03-2017 02:48 PM
    What engine for my 69 220 auto W115? 560 ahoy Vintage Mercedes-Benz 6 09-10-2011 07:34 PM
    MB 200 w115 engine question PBobbenB Vintage Mercedes-Benz 4 05-31-2010 05:12 AM
    W115 Engine Swap arthrdgls Vintage Mercedes-Benz 3 06-12-2007 07:26 PM
    w115 rims, engine senior Vintage Mercedes-Benz 1 10-13-2005 02:29 PM
