How do I compression test a 280 SEL 4,5 1972? Hot or cold etc - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 06-20-2011, 12:14 PM Thread Starter
Date registered: Sep 2010
Does someone have an resource about this? I only found this article, but it was on a 116, but maybe the same procedure on a W108 4,5 V8 car?
http://handbook.w116.org/Engine/107/M117_45/01-010.pdf
Thanks!
280SEL4,5 is offline
post #2 of 3 (permalink) Old 06-22-2011, 10:43 AM
Date registered: Jul 2004
Vehicle: 1971 280SE 3.5 Coupe
Quoted: 8 Post(s)
Engine at operating temp, throttle wide open. Insure the FI and ignition is disabled.
Tony
280SE 3.5 Coupe
Stick shift
3.27 Axle
5.6 Iron block build in progress
3.5 Tony is offline
post #3 of 3 (permalink) Old 06-22-2011, 11:02 AM Thread Starter
Is it enough to pull out the small contacts to the nozzles (8) and pull of wire to the coil from the distributor?
    Compression test MOGME Unimog 10 10-07-2009 07:25 PM
    Compression Test clipster R129 SL-Class 1 06-17-2009 04:18 PM
    Compression Test $420!! ??? Cancer_Researcher W123 E,CE,D,CD,TD,TE Class 20 04-29-2009 04:10 PM
    compression test??? mountainredneck W123 E,CE,D,CD,TD,TE Class 11 01-29-2008 05:06 AM
    compression test ? 1.816vgti W201 190-Class 0 08-31-2003 11:39 AM
