w115 idle problems - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 06-03-2011, 04:27 PM Thread Starter
Date registered: Feb 2011
Vehicle: 1967 250 S
w115 idle problems
Hello, all!
Don't post here much, but I honestly wouldn't be too helpful as I'm not very mechanically inclined.
My 1967 250S has recently been stalling upon acceleration and/or idle. It happens when she is cold, yes, but this problem is new. I usually would wait for her to warm up to about 100 degree and she would be fine, but lately, that will make her stall if I have to come to a complete stop. If she is not all the way to just under 175 degrees, if I don't put her into neutral she will most likely stall. Also a new problem. I actually liked this one much better than my previous Benz (w114), because I didn't need to wait for it to warm up as long.
I want to raise the idle a little to see if that helps (unless there is something obvious I am missing?). However, I'm not exactly sure where the idle is located (dual carbs). I unfortunately do not have a user manual.
Thanks for any help!
wrongemboyo is offline
post #2 of 2 (permalink) Old 06-04-2011, 02:20 AM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 95 Post(s)
You've got twin carbs, right? I suggest you take them off and clean them thoroughly, and replace the seals between the carb and manifold. You might also look into a rebuild kit for them - no idea what the price would be...
Grubeguy is offline
    idle problems on 420 SEL opie W126 S,SE,SEC,SEL,SD,SDL Class 4 09-19-2010 11:39 AM
    Idle Problems figgi01 W201 190-Class 19 10-16-2009 12:47 PM
    W115 Radiator Problems 560 ahoy Vintage Mercedes-Benz 2 08-25-2009 12:44 PM
    Idle problems jer811 Vintage Mercedes-Benz 10 06-28-2004 12:30 PM
    Idle problems Guest (MBNZ) W201 190-Class 3 07-25-2001 03:57 PM
