air conditioner - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 06-03-2011, 04:25 PM Thread Starter
Date registered: Jun 2011
Vehicle: 1984 380 SL
air conditioner
1984 380 sl - a/c not blowing cold - does this car use the R-34 to add freon
Grame is offline
post #2 of 5 (permalink) Old 06-04-2011, 10:28 AM
ktmripper's Avatar
Date registered: Jun 2010
Unless it has been converted, your car uses r-12 freon.
ktmripper is offline
post #3 of 5 (permalink) Old 06-04-2011, 02:12 PM Thread Starter
Is there an easy way to tell if it has been converted - short of tasking it to a mechanic -
Grame is offline
post #4 of 5 (permalink) Old 06-06-2011, 12:21 PM
Date registered: Jul 2004
Vehicle: 1971 280SE 3.5 Coupe
Quoted: 8 Post(s)
There should be sticker under hood if it was converted. If your AC dosen't work there could be multiple causes but at a miimum you will need the system flushed, dryer replaced, probably compressor replaced and system pressurized with dry gas to check for leaks. Then you can evaluate where you are and repair as needed. So if the system was converted it's kind of irrelivant at this point. if you just put more freon in it it will fail again shortly if it works at all.
280SE 3.5 Coupe
Stick shift
3.27 Axle
5.6 Iron block build in progress
3.5 Tony is offline
post #5 of 5 (permalink) Old 06-06-2011, 03:22 PM
Date registered: Jan 2007
Vehicle: 1968 250SL; 1970 280SE 3.5 Cabriolet (EURO Version); 1987 560SL
The R134a conversions usually have a light blue cap on the valve where refrigerant is added. The R134a valve is larger than the R12. The R134a valve (male) does not have threads on the outside -- it uses a lock ring on the female side to hold the accessory hose (that the refrigerant can is hooked to). The R12 valve (male) has treads on the outside. Do a search on Google for A/C recharging and photos will display what I'm talking about. You could also ask someone at PepBoys or Autozone to step outside and look for you. If you need can find them for sale on Craigslist typically. Good luck!
JPMose is offline
    Air Conditioner Help MB7882 W202 C-Class 5 08-09-2010 06:43 PM
    Air Conditioner PhatInAz General Mercedes-Benz 0 07-16-2008 09:13 PM
    Air Conditioner does what it wants.... Eugene 87 300 TDT W124 E,CE,D,TD Class 0 08-17-2005 02:37 PM
    Air Conditioner lancer W123 E,CE,D,CD,TD,TE Class 14 05-29-2005 08:22 PM
    Air conditioner Ignatz W201 190-Class 2 05-19-2004 05:44 PM
