450 SEL Transmission - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 05-28-2011, 06:24 PM Thread Starter
Date registered: May 2011
Vehicle: 1975 450 SEL
I have a 1975 450 SEL, very low mileage. Audometer says less than 50,000. Everything original, everything works. Only trouble I've been experiencing is a loss of power that often occurs when the upper gears are engaging (or not). has anyone else experienced this. I was wondering if it is a common problem with these old cars, even low mileage cars like mine. When I first got the car the accelerator linkage was sticking, and a good cleaning fixed that. Hopefully this is a simple problem too.
drewheyl is offline
post #2 of 2 (permalink) Old 05-28-2011, 06:28 PM
ktmripper's Avatar
Date registered: Jun 2010
Fuel filter.
ktmripper is offline
    Transmission issues (1990 300E, 3.0L, 722.5 transmission) Eric@StarSuzuki W124 E,CE,D,TD Class 5 04-13-2011 07:29 PM
    2000 SL500 - I need transmission work should I use a transmission shop or an Indy khmlucas R129 SL-Class 19 08-25-2010 09:31 AM
    What does this transmission part does + Transmission leak ? Pics attached Vlad-W124 W124 E,CE,D,TD Class 4 06-03-2010 10:27 AM
    Automatic transmission question: anyone knows how to make the transmission shift at a higher RPM, DanPro1 R170 SLK-Class 8 10-07-2002 02:35 PM
    Prefacelift SLK: shift-knobs for automatic transmission can be installed on manual transmission? Marcello (Piacenza - R170 SLK-Class 3 04-26-2002 11:05 AM
