Broken belt tensioner on my M115 engine a/c condenser (1977 4 dr 230) - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 05-26-2011, 07:09 AM Thread Starter
Date registered: May 2011
Vehicle: 1970 Mercedes 250c, 1977 mercedes 230 (put to rest at a junyard she served me well)
I changed all the belts in my '77 230 yesterday and found one of the teeth on the little tensioner cog for the a/c condenser was broken.
I was able to move it enough to slightly loosen the belt and change it, but it took a lot of unpleasantness and sweating, if you know what I mean. Now the belt is still looser than it should be and squeals at low speeds when I turn the a/c fan on.
Is anyone familiar with the belt tension-ing on an m115 engine? Any documentation on belt tensioning procedure? Does anyone know where I can find the little star cog & bolt for the tensioner and replace it?
makinfrenzinmybenz is offline
post #2 of 2 (permalink) Old 05-29-2011, 07:46 AM Thread Starter
Germanstar.net
They seem to have everything.
If it's not listed in the catalog they probably have it if you contact them.
I am a big fan of germanstar.net
    Need Engine Mounts and Belt Tensioner Damper V12StealthHunter W201 190-Class 8 12-30-2012 02:42 PM
    Belt tensioner broken egster W202 C-Class 0 01-15-2010 08:46 AM
    New style belt tensioner -older 104 engine latief W124 E,CE,D,TD Class 0 09-25-2009 10:54 AM
    Removing the belt tensioner on a 104.992 engine soundquest W124 E,CE,D,TD Class 2 05-22-2009 08:56 AM
    M103 engine belt tensioner: testing one? ron in sc W124 E,CE,D,TD Class 2 02-19-2009 08:29 AM
