w108 steering box problem - Page 2 - Mercedes-Benz Forum
post #11 of 18 (permalink) Old 05-24-2011, 06:41 AM
GGR
Date registered: Apr 2006
Vehicle: W111 Coupe
Quoted: 19 Post(s)
Originally Posted by Jazzenco View Post
Tomorrow, I will jack up car and try to reach there...Thank you very much GGR for suggestions and detailed information...
You're welcome. Don't jack the car, only the engine.
GGR is offline
post #12 of 18 (permalink) Old 05-24-2011, 10:17 PM
Date registered: Jul 2004
Vehicle: 1971 280SE 3.5 Coupe
Quoted: 8 Post(s)
Be sure to check the steering coupler. It has bushings that when worn will add alot of play.
Tony
280SE 3.5 Coupe
Stick shift
3.27 Axle
5.6 Iron block build in progress
3.5 Tony is offline
post #13 of 18 (permalink) Old 05-25-2011, 04:45 AM
GGR
Vehicle: W111 Coupe
Quoted: 19 Post(s)
Good point. Start with that. The steering coupler is right in between the steering box and the firewall.
GGR is offline
post #14 of 18 (permalink) Old 05-30-2011, 07:02 PM
Date registered: Sep 2008
Vehicle: 1975 450SL
Quoted: 15 Post(s)
The steering coupler is a well known source of wheel play. There are rubber bushings that disintegrate with age. Be careful that you make marks on the shafts before you take it apart, to make sure you are lined up properly when you put it back together. Just be glad you are not trying to do it on a 107. Benz there, done that, got the T-shirt. And the scars.
RadioTek is offline
post #15 of 18 (permalink) Old 05-31-2011, 07:13 AM Thread Starter
Date registered: Jun 2009
Vehicle: 280SE 3.5
Hi everybody,
I finally reached that hex nut yesterday which is very difficult to reach and too much time as it remains exactly under exhaust manifold.I was able to reduce play little bit however still more than 10% free play exist on steering wheel.Thank you very much for great suggestion about steering coupler. I will check that bushings on steering coupler.I forgot about them)I'm sure they are worn.
Do I need to mark position before removal coupler from the lower shaft to steering coupler or from both sides?
Regards,
Kutluhan
Jazzenco is offline
post #16 of 18 (permalink) Old 05-31-2011, 05:13 PM
Quoted: 8 Post(s)
The adjustment mentioned does not act directly on the steering shaft but adjusts the spring tension pulling the ball on the steering shaft into the socket on the power piston. The ball and socket are a very precise fit so if it is actually loose no amount of tightening will help. This is not a adjustment that "changes" over time to make up for wear. Most likely the looseness is in the suspension somewhere(Tie rod ends, center link, idler arm, king pins or the coupler). You can purchase just the bushings for the coupler. Also insure the bolts holding on the box are tight. Sounds obvious but it has happened.
I doubt your box is worn out. My coupe has many miles and the box feels like new.
Tony
280SE 3.5 Coupe
Stick shift
3.27 Axle
3.5 Tony is offline
post #17 of 18 (permalink) Old 05-31-2011, 06:25 PM
ktmripper's Avatar
Date registered: Jun 2010
I kind of assumed the play had already been isolated to the gearbox. In order to do this , with car turned off and key on ,have someone rock wheel back and forth. If there is play in the coupler you can see it. If the play is in the gearbox, the input shaft will move but the pitmam arm will not. If the play is in the bushings, tie ends you probably won't feel any play at a standstill. If the play is in the gearbox try the adjustment first. It is a very common problem.
ktmripper is offline
post #18 of 18 (permalink) Old 06-05-2011, 07:17 AM Thread Starter
Vehicle: 280SE 3.5
Yes exactly!,yesterday, I removed steering coupler.Bushings completely finished) one was broken just after removal.I will replace them with new ones). By the way, I already removed steering box for maintenance,I realized that vertical piston seal deformed and therefore lower case of steering box is a little bit oily,as it was removed, I will replace its all seal rings and check out for wearing as well.
It took my complete day to remove all steering box,it was terrible, specially, removal of drag link and tie end rods, but it worth I think.Now I was able to access everything.
I will try to upload pictures in few days...
Regards,
Kutluhan
Jazzenco is offline
    HELP! w108 power-steering trouble gclass Vintage Mercedes-Benz 13 04-18-2011 05:28 PM
    w108 280se Heat and coolant problem!! D&WCali Vintage Mercedes-Benz 10 12-16-2010 03:12 PM
    W108 Power Steering Reservoir Leak tecrekka Vintage Mercedes-Benz 6 11-05-2010 07:45 PM
    w108 Door Problem correlation Vintage Mercedes-Benz 8 07-01-2009 08:42 PM
    W108 V8 Power Steering Pump 56kabrio Vintage Mercedes-Benz 1 10-23-2006 06:13 AM
