1972 280SEL 4,5 1972. Need new motor Wiring Harness and new throttle position sensor - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 05-12-2011, 04:01 PM Thread Starter
Date registered: Sep 2010
My motor wiring harness have been spliced in. Where can I buy new to my car? The diagnosis of my car also said that the throttle position sensor didnt respond. So my mechanic said that I have to renew it.
Thanks.
280SEL4,5 is offline
post #2 of 4 (permalink) Old 05-14-2011, 06:48 AM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 99 Post(s)
Wiring harnesses MIGHT be available from the classic center, but I tried a few years ago and came up with nothing. You might have to have it built by a custom shop.
Call the bullshit flag on the TPS - mine was "bad" also, but I opened it up and cleaned the thing out with isopropol alcohol (contact cleaner) and a stff brush. The innards are nothing more than coiled wire - it's a potentiometer.
Go to the online resources portion of the forum. There are a bunch of articles posted about our fuel systems, including how to diagnose your own problems.
Grubeguy is offline
post #3 of 4 (permalink) Old 05-31-2011, 05:42 AM Thread Starter
Thanks. I have opened the TPS and cleaned before, but I will do agian with oxide clean. I hear the 20 clicks and no clicks when declerate. So guess the TPS is in order. When I am driving, specially holding a steady speed about (lets say) 45-50 Miles/hour, then I notice very small jerk driving. This is a bit irritating since you want it to run without it.
post #4 of 4 (permalink) Old 05-31-2011, 09:25 AM
Grubeguy's Avatar
Quoted: 99 Post(s)
Hmmmm. I had the same jerking issue with mine. I found that my timing was off. First clue was when I turned on the AC, and the jerking would go away (turning on the AC advances the timing by 5 degrees).
Years later, chasing down a different issue, the mechanic I had wanted to rebuild or replace the guts of my distributor, including springs and counterweights. I never gave credence to the notion that stuff like that would go bad, but my car's never run so smoothly as it did after that.
Try advancing your timing by 5 degrees and see what happens.
Grubeguy is offline
    1972 280sel mprider Vintage Mercedes-Benz 2 11-04-2008 01:27 PM
    1972 280SE 4.5L car and 1972 280SEL 4.5L parts car for sale benzmeister_WI For Sale/Wanted/Trade/Giveaway 6 09-10-2007 05:38 AM
    1972 280sel 4.5 One Owner! CA car. Autobahnfahrer For Sale/Wanted/Trade/Giveaway 1 09-19-2006 09:08 AM
    Is this 280sel a 1972 or 1973? ldshull Vintage Mercedes-Benz 8 01-29-2006 08:18 PM
    1972 250 wiring harness? chaunsy Vintage Mercedes-Benz 0 12-06-2004 07:26 PM
