Water Leaking through Windshield Headrail - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 05-04-2011, 10:28 AM Thread Starter
Date registered: May 2011
Vehicle: 1986 560SL & 2004 E55 AMG
Have '86 560SL - recently, when car is caught in rain, water leaks into cabin... dripping off of rearview mirror or when cornering, leaks out of dome lights in headrail of front window. The rubber gasket between headrail and convertable top is in good condition and keeps the top of the headrail dry. Happens if the car is parked or being driven (it is worse when driving.) I am thinking that the seal between the front window and the frame has degraded. Is there a way to check this? Is there an easy fix?
Hansrk is offline
post #2 of 3 (permalink) Old 05-06-2011, 08:41 PM
Date registered: Sep 2008
Vehicle: 1975 450SL
Quoted: 15 Post(s)
These were glued in windshields, the glue may have degraded over time and is leaking. If you go over to the 107 forum, there will be a lot of very dedicated people that will be quite wiling to help.
RadioTek is offline
post #3 of 3 (permalink) Old 05-07-2011, 02:25 AM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 95 Post(s)
The simplest means of checking a windshield gasket is with a garden hose and a friend. Starting from the bottom of the windshield, spray a gentle stream and move your way up until you find a leak. Or two.
I did this with my 108's leaking rear windscreen. Once I found the leak, I allowed it to dry out a few days and then sealed the outside portion of the gasket with black sealant - it cost me something lie $2.50 at Lowes. Once it dried, I used a razor blade to scrape away the excess.
I'm not familiar with your car's molding or chromed bits, so you may have to remove beauty pieces to get to the gasket.
Grubeguy is offline
    leaking windshield washer pump? MAX500 W163 M-Class 13 10-01-2012 02:29 AM
    Windshield water pump leaking SkyFox955 W211 E-Class 1 12-07-2009 07:40 AM
    Windshield gasket leaking. timbro W123 E,CE,D,CD,TD,TE Class 14 11-22-2007 11:44 AM
    Windshield Washer Reservoir leaking @TheWheel W163 M-Class 2 01-10-2005 05:46 PM
    Leaking Windshield preet112 W126 S,SE,SEC,SEL,SD,SDL Class 4 05-05-2003 08:59 AM
