wiring dilema - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 04-28-2011, 05:26 PM Thread Starter
Date registered: Mar 2011
wiring dilema
Hello, I am hoping someone can provide me some insight into an electrical problem on my 1976 300D. The brake, hazards,turn signals and possibly other lights won't work. From the diagrams in my manuals it appears that all these are functions of the ignition being in the run pos. (except the hazards). does anyone have a wiring diagram showing where the fuse block is fed from and which fuses feed what. Thanks
balden is offline
post #2 of 6 (permalink) Old 04-30-2011, 10:21 AM
Govert70227's Avatar
Date registered: Oct 2009
Vehicle: 2000 VW Golf Variant
Quoted: 4 Post(s)
The fuse box is fed from the battery. Inside the lid of the fuse box there is a piece of paper saying which fuse is responsible for what circuit.
The fuse box is in the engine bay on the firewall.
Govert70227 is offline
post #3 of 6 (permalink) Old 04-30-2011, 03:54 PM Thread Starter
Thanks for the reply, however, apparently my paper is missing from the fuse box which says what feeds what, and, more importantly, whatever feeds the fuse panel is not doing so. Does in come from the ignition or a relay switch or what? THIS is my dilemma. I both hanes and chiltons manuals, neither one of them show a diagram of the system.
balden is offline
post #4 of 6 (permalink) Old 05-02-2011, 09:58 AM
240d Tanner's Avatar
Date registered: Apr 2009
Hey I have a factory diagram from the cd. Is this what you need? It is to large a pdf to post here. pm me with your email and I will send it to you.
240d Tanner is offline
post #5 of 6 (permalink) Old 12-01-2011, 01:04 PM
Date registered: Nov 2010
I have a question for you if you do not mind. I have a 1976 300D and the power windows stoped working. I can not locate the fuse for the power windows. Do you know where it is?.
Thanks for your help.
Sammyboy is offline
post #6 of 6 (permalink) Old 12-02-2011, 02:17 PM
Date registered: Sep 2008
Vehicle: 1975 450SL
Quoted: 15 Post(s)
One common problem with electrical gremlins is that the aluminum fuses have a dissimilar-metal corrosion problem with the brass fuse holder. A temporary fix is to 'spin' the fuses in their holders, breaking loose the corrosion.
Before you do this job, go to the auto parts store and get a packet or two of clectrical contact grease. These should be very inexpensive.
The cure for this is to remove each fuse, one at a time, and buff the ends with a heavy cloth (canvas or denim). Before you put each fuse back in, put a tiny dab of the contact grease on each end. This prevents air and moisture from getting to the contact points, eliminating future corrosion.
There are fuse kits available with brass tipped fuses, rather than aluminum, but some people have reported difficulty finding them.
Good luck.
RadioTek is offline
    SL Dilema treasurehuntjs R/C107 SL/SLC Class 11 12-22-2006 11:35 AM
    my dilema cjaama G-Class 10 09-10-2006 09:47 AM
    My dilema amcmahon R171 SLK-Class 7 12-31-2004 12:53 PM
    Dilema what to do? Dreamin430Dreams C208/A208 CLK-Class 15 03-04-2004 01:08 AM
    DILEMA? ML55AMG2k W163 M-Class 31 10-16-2002 04:05 PM
