300D-Correct Fuse Amperes. - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 04-27-2011, 12:14 AM Thread Starter
Date registered: Dec 2009
Vehicle: 1976 300D
Quoted: 2 Post(s)
Send a message via Yahoo to amarbenj
As i look inside the fuse, there are numbers alloted for each fuse. how will i know if i have placed the correct fuse amperes? also, my glow plug located near the shifting gear sometimes dont light up upon start up together with the light on the right front. As i check the fuses, one was burnt or don't function well until i replaced it with a new one. This usually happens. what could be the reason? please help. thanks.
amarbenj is offline
post #2 of 3 (permalink) Old 05-22-2011, 09:56 PM
Date registered: May 2011
There should be a piece of paper under the cover specifying which fuse protects what.
CenCalBenz is offline
post #3 of 3 (permalink) Old 05-23-2011, 12:59 AM
benzmizer's Avatar
Vehicle: 1983 240d AT; 1993 e320 AT
Quoted: 4 Post(s)
Talking
Kababayan! Dito pa tayo nagkita. =D
Check this link.... this would help you. MBCluster - ServicePage
benzmizer is online now
    1983 300D Fuse 14 jrsaxe W123 E,CE,D,CD,TD,TE Class 3 09-09-2009 05:13 AM
    560SL Correct Fuse? Fiorano R/C107 SL/SLC Class 4 06-04-2009 05:56 AM
    1976 fuse locations and correct amp ratings theob Vintage Mercedes-Benz 2 02-04-2008 09:48 PM
    300te - Correct Fuse Size Needed Ward W124 E,CE,D,TD Class 2 10-27-2007 12:27 PM
    300D fuse box lemmyb W123 E,CE,D,CD,TD,TE Class 5 09-02-2004 02:44 PM
