450 SlC engine removal - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 04-26-2011, 12:47 PM Thread Starter
450
Date registered: Apr 2011
Vehicle: 450slc 1979
Hello. I have broken 4 exhaust manifold bolts in the cylinder head. I want to raise the engine to drill out the broken studs. Please advise where I need to attach chains to hoist the engine up. Are there special lifting points?
450 is offline
post #2 of 5 (permalink) Old 04-26-2011, 10:28 PM
Date registered: Sep 2008
Vehicle: 1975 450SL
Quoted: 15 Post(s)
I would suggest that you go over to the 107 forum, and ask there. It's very active, and there are quite a few people that have done a lot to their vehicles. There would probably even be a thread with pictures.
There is even a sticky thread with links to the service manual.
Good luck.
RadioTek is offline
post #3 of 5 (permalink) Old 04-26-2011, 10:37 PM Thread Starter
450
Hello again. Thank you very much for the advice. much appreciated!
450 is offline
post #4 of 5 (permalink) Old 04-27-2011, 03:04 AM
drew56cus's Avatar
Date registered: Oct 2006
Vehicle: 1965 220SE sedan (finnie) with 450SE conversion, 1964 220SE coupe project, 1966 300SE coupe
Quoted: 33 Post(s)
I assume it would be the same as my 450SE motor from a W116.
There are three lifting lugs on the motor that are rings - one at the front near the radiator hose and two at the back of the motor (one per side), bolted to the intake manifold.
drew56cus is offline
post #5 of 5 (permalink) Old 11-30-2014, 02:23 AM
Date registered: Nov 2014
Thanks for your very clear advice.
I had the same problem with the TDC on right side new sprocket lining up dead on the mark. It seems that the teeth on the New sprocket replacement were half a tooth out of line with the original sprocket, and hence the difference. It sems to me that is the problem rather than the chain.
Can you please help explain how to remove the lower chain guides which are hidden deep in the engine?? It seems that the front plate between cylinder head and oil sump and camshaft flywheel need to be removed which is a big job.
Can you please suggest a link to do this work without removal of the engine ??
Propap is offline
1979 450 SLC Radiator Removal kbunting R/C107 SL/SLC Class 11 07-15-2013 02:07 PM
C55 AMG engine into 450 SLC HECSA R/C107 SL/SLC Class 5 04-29-2011 05:02 AM
Drivers Seat removal 450 SLC henderson R/C107 SL/SLC Class 4 01-05-2010 07:00 AM
Looking for a good 450 SLC 5.0 engine GGR R/C107 SL/SLC Class 17 03-05-2009 06:25 PM
450 SLC 5.0 engine, manual and interior SAH R/C107 SL/SLC Class 2 03-26-2004 06:02 PM
