Vacuum Door Lock Questions - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 04-25-2011, 02:59 PM Thread Starter
Date registered: Jan 2010
Can someone tell me where the vacuum resevoir and the manifold vacuum take off port are on a w108 M117?
porterthe is offline
post #2 of 2 (permalink) Old 04-27-2011, 03:07 AM
drew56cus's Avatar
Date registered: Oct 2006
Vehicle: 1965 220SE sedan (finnie) with 450SE conversion, 1964 220SE coupe project, 1966 300SE coupe
Quoted: 33 Post(s)
Have a look at the back of the motor near the throttle linkage - there is a round damper looking thing that has a big and a little pipe outlet on it. I think the little one was connected to the door lock vacuum.
The trans has a vacuum connection on it, so you could also trace it up to the motor. I think it goes to this same place.
drew56cus is offline
    Vacuum lock questions. RadioTek R/C107 SL/SLC Class 4 10-21-2010 12:45 PM
    '91 350sdl door lock vacuum pump andydiesel W126 S,SE,SEC,SEL,SD,SDL Class 0 03-04-2010 01:16 PM
    Vacuum Door Lock Question alfredgee W123 E,CE,D,CD,TD,TE Class 10 07-12-2009 03:59 PM
    I need a new vacuum door lock piston yossir29 W126 S,SE,SEC,SEL,SD,SDL Class 5 02-24-2009 01:37 AM
    door lock vacuum pump davesbenz W126 S,SE,SEC,SEL,SD,SDL Class 4 07-27-2005 09:27 AM
