replaced trans mount and flex disc and now car shakes while taking off. - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 04-25-2011, 09:54 AM Thread Starter
GGR
Date registered: Apr 2006
Vehicle: W111 Coupe
Quoted: 19 Post(s)
I recently replaced both trans mount and flex disc in one go on my W111 Coupe. since then there is a slight shake when I take off from a stop. I wonder if the culprit is th trans mount or the flex disc. I got both from Autohaus AZ and I guess they are aftermarket parts. The trans mount is common to number of models, including W108 4.5, r107, W126 etc.
If anybody got the same experience and could tell me which of the two is creating the problem would be useful.
Thanks!
GGR is offline
post #2 of 5 (permalink) Old 04-27-2011, 11:10 AM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 104 Post(s)
There's a bushing in the back of the driveshaft too, where it meets the rear end (if memory serves). Was that replaced?
Grubeguy is offline
post #3 of 5 (permalink) Old 04-27-2011, 11:16 AM Thread Starter
GGR
Vehicle: W111 Coupe
Quoted: 19 Post(s)
No bushing on my car there, just the u-joint that bolts directly to the diff input flange. Problem appeared immediately after replacing trans mount and flex disc, so it must be one of the two. I initially thought it was the flexdisc but now I'm wondering about the trans mount. The shake is a bit as if the trans was moving left and right and there is a sound of distorte rubber when this happens.
GGR is offline
post #4 of 5 (permalink) Old 04-27-2011, 02:53 PM
barnumlives's Avatar
Date registered: Aug 2009
Vehicle: W114/115 220d (1972) [sold] and W123 300tdt (1984) and two L406DG's (1967)
maybe you forgot this
after reinstalling the driveshaft but before tightening the bolts for the center bearing mount and the two large nuts on the driveshaft, you should roll the car back and forth several feet. then torque these items to spec.
if you missed this step the vibration/shudder you are experiencing may be from locking the parts in place before they've had a chance to find their 'comfort zone'.
barnumlives is offline
post #5 of 5 (permalink) Old 04-28-2011, 05:44 AM Thread Starter
GGR
Vehicle: W111 Coupe
Quoted: 19 Post(s)
Thanks, will do when I reinstall everything.
GGR is offline
Flex disc MB_FPK W123 E,CE,D,CD,TD,TE Class 2 08-11-2009 07:48 AM
Flex disc - DONE! Cyberbach W124 E,CE,D,TD Class 8 04-05-2007 05:29 PM
Flex Disc dahappybanana W124 E,CE,D,TD Class 1 11-10-2005 04:29 AM
What does Flex Disc do? Thanks for your help!! Guest (MBNZ) W124 E,CE,D,TD Class 2 07-15-2002 06:14 AM
Flex disc Guest (MBNZ) W124 E,CE,D,TD Class 4 01-31-2002 01:04 PM
