Ignition Switch 1975 300D - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 04-20-2011, 09:26 AM Thread Starter
Date registered: Nov 2010
Vehicle: 1975 Mercedes-Benz 300D
Post Ignition Switch 1975 300D
Hey everyone, I'm currently in the process of a starter and ignition switch job on my 1975 300D and can't figure out for the life of me how the hell I'm supposed to remove the dash to get to the ignition switch, every bolt I can find has been removed. Is there an easier way to access the ignition switch so I can pull it and replace it (just the electrical bit with the spring)? Also, any ideas about how to make starter removal less of a pain in the ass would be super appreciated!
Thanks in advance for any help!
Mitokia is offline
post #2 of 7 (permalink) Old 04-20-2011, 10:35 AM
Govert70227's Avatar
Date registered: Oct 2009
Vehicle: 2000 VW Golf Variant
Quoted: 4 Post(s)
Take out the instrument panel, than you can access the ignition switch and lock.
Govert70227 is offline
post #3 of 7 (permalink) Old 04-20-2011, 10:48 AM Thread Starter
Smile
Thanks, how exactly do I get the instrument panel out though?
Mitokia is offline
post #4 of 7 (permalink) Old 04-20-2011, 11:39 AM
Date registered: Dec 2004
Vehicle: 1972 280CE
Quoted: 109 Post(s)
Pull
With best regards
Al
Check out the W114, W115 /8 enthusiast forum http://www.stroke8.org
My 280SL restoration
alabbasi is offline
post #5 of 7 (permalink) Old 04-20-2011, 01:57 PM
Quoted: 4 Post(s)
or push from the back. You have to unscrew the speedometer cable and the oil line and unplug the electrics.
Don't forget to connect to oil line before starting!
post #6 of 7 (permalink) Old 04-20-2011, 04:00 PM
Date registered: Sep 2008
Vehicle: 1975 450SL
Quoted: 15 Post(s)
Remove steering wheel first. To do this, you pull the center off, and loosen the big nut holding the wheel . You need to have the ignition in the 'on' position, so the wheel is free to turn. You do NOT want to try to turn against the wheel lock. Trying to work against the steering wheel lock will break that, and that's expensive, aside from being a severe pain.
Get a piece of wood, and brace from one of the wheel spokes to the floor. Pad the end at the wheel spoke with a rag or some such. If it's never been off, it may require a bit of torqe to get it loose, but that's why you brace it.
Once the wheel is off, you have complete access to the cluster. If you can't wiggle the cluster out, there are some hook tools available that let you slide them in, turn, and pull.
While you're in there, change out your light bulbs and add an additional ground lead from a screw holding down the circuit board to a convenient bolt on the frame behind the cluster. Put a male/female connector in the lead for future re-entry.
Be very careful with the oil line. Whatever you do, DO NOT try to start the car with the cluster out. You will have a pressurized oil line pointed at your chest. This is not good.
RadioTek is offline
post #7 of 7 (permalink) Old 04-20-2011, 09:40 PM Thread Starter
Talking
Hey guys, I was able to get the instrument cluster out just by loosening around the edges and pulling, didn't need to remove the steering wheel or anything like that. Good idea adding an extra ground, I just pulled apart the broken odometer assembly, cleaned it, regreased it, and reassembled it so it might possibly work now. With the cluster out I had perfect access to the ignition switch, now it's time to figure out what I'm going to do about that starter. Getting it out is going to be a pain from what I've heard.
Mitokia is offline
    300D ignition switch/tumbler/key trouble. El DJ W124 E,CE,D,TD Class 8 08-04-2011 11:19 AM
    1976 300D intermittent starting issue, ignition switch? Moozak Vintage Mercedes-Benz 1 10-29-2010 07:58 PM
    1975 450 SL ignition lock Duba R/C107 SL/SLC Class 10 09-23-2010 03:40 PM
    1975 450sl: need an electronic Ignition module replacement BBenzick Vintage Mercedes-Benz 1 10-28-2009 11:09 PM
    92 300D ignition switch woes rhlbenz W124 E,CE,D,TD Class 3 03-07-2009 12:07 AM
