Questions on Pulling a Head - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 04-09-2011, 05:28 PM Thread Starter
Date registered: Nov 2008
Vehicle: 1981 300TD 310k--1966 230 165k--1970 280se 172k
Quoted: 33 Post(s)
I'm preparing to pull the head on my '66 230 with the m180 engine to replace the head gasket and find a coolent leak into a combustion chamber. I've never pulled a head with an overhead cam before and after reading the FSM, I'm still unclear on a few things:
1) After removing the tensioner and upper guides, can I just tie the chain off to the cam sprocket and drop it into the cavity?
2) If not, can I just mark the chain and sprocket, remove the chain from the sprocket, and drop the chain into the cavity?
3) In either case, how I can I be sure that the chain won't come off the crank sprocket?
Thanks, everyone!
1981 300TD--310k miles
1970 280sel--172k miles
1966 230--162k miles
carpenterman is offline
post #2 of 2 (permalink) Old 04-10-2011, 12:14 AM
Date registered: Jun 2010
Vehicle: 1966 MB 200; Porsche 914 (6); Porsche 914 (Chev 350); 36 ford
Quoted: 16 Post(s)
I have a 1966 200, and did just the repair that you are going to do. Do a searh and you can find my thread. I just pulled the chain and guide, and carefully dropped it into the cavity. I did tie off the chain and then used the wire to drop the chain. (I kept the wire on the chain to be able to easily pull the chain back out. I found the upper sprocket kept the chain in place. But, this is for the 200, and I am not sure if the 230 is the same.
-- brett
bfrymire is offline
    Bad Glow Plug - Pulling Cylinder Head tony1963 W210 E-Class 16 06-16-2012 05:04 AM
    new head unit..several questions slk0230 Audio & Telematics Forum 1 12-27-2010 11:03 PM
    Head questions Help! mikes89' W126 S,SE,SEC,SEL,SD,SDL Class 7 07-20-2007 07:52 AM
    Head Gasket Questions WhiteSEC560 W126 S,SE,SEC,SEL,SD,SDL Class 11 06-09-2007 08:21 AM
    How hard is change valve guides without pulling the head? AMG500SEC W126 S,SE,SEC,SEL,SD,SDL Class 3 08-20-2003 08:59 AM
