Getting '73 450 SL on road after 5 years - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 04-05-2011, 05:28 AM Thread Starter
Date registered: Apr 2011
Smile Getting '73 450 SL on road after 5 years
Hello everyone,
Going to be getting my wife's 1973 450 SL (automatic) out of storage after 5 years to enjoy the summer weather with the top down and was looking for any advice on things to replace or inspect to get her running again. She ran pretty well before it was parked. Only issue it ever had was bad starter that got replaced. I'm anticipating the worst but hoping for the best. Car was in really good shape. No visible rust, interior was really nice and had newer benz rims/tires. I'll try to track down photos.
My list included:
New battery
New belt(s)
Distributor Cap/Rotor/Points
Change Oil & Filter
Inspect tires/steering/suspension
Fresh gas
New air filter
Check & top off fluids
Questions:
What tranny fluid should I use in an auto if its low?
Any well known issues to look for on this model?
Hoping all goes well so it doesn't eat away at my '68 Mustang resto budget but we'll see. Thanks in advance.
munky1018 is offline
post #2 of 7 (permalink) Old 04-05-2011, 09:56 PM
re-prioritize the list
Check & top off all fluids
New battery Start and warm up over 1/2hr
Change Oil & Filter
The above is required
New belt(s) (maybe)
Distributor Cap/Rotor/Points (maybe)
New air filter (remove blow back thru)
You may be stunned to know some of the cars I've made run before doing everything, take it a step at a time.
Unless your first ride is a thousand miles.
Brian O
bostosh is offline
post #3 of 7 (permalink) Old 04-06-2011, 03:48 AM
Ed Mclass's Avatar
Vehicle: 90 300 SE ,85 300 GD
Wink Ceramic Fuses
Those old fuses can oxidize when sitting up for long periods. It would be a good idea to replace them now with new ones. They can look "okay" but still fail. It usually happens at the worst time, fuel pump, window regulators or lamps don't work.
Ed Mclass is offline
post #4 of 7 (permalink) Old 04-11-2011, 02:59 PM
Vehicle: 1967 250 SL
I would also highly recommend a close look at the brake fluid and brake lines. MB usually says two years for a change out of the fluid because of the water it will pick up. The hoses and lines can cause all sorts of bad things to happen.
JonB 113SL is offline
post #5 of 7 (permalink) Old 04-28-2011, 05:22 PM
Angel76's Avatar
Vehicle: 1976 450 SE
Pretty. Hope all goes well. I am also restoring a 76 450. Took it out yesterday for first time since I rescued it several months ago. Needed a lot of new wires and hoses. Rats dined at the Benz cafe during prior owners reign. Now it needs new belts and tires. Good luck to us both!!
Angel76 is offline
post #6 of 7 (permalink) Old 05-04-2011, 03:16 PM
Date registered: May 2011
Vehicle: 1973 450SL
I am also restoring / repairing a 1973 450SL that sat for 8 years. I needed to replace the water pump and had garbage in the gas tank. At least put some fuel conditioner in the tank. At worst drop the tank and have it cleaned professionally.
STK4949 is offline
post #7 of 7 (permalink) Old 05-06-2011, 08:38 PM
Date registered: Sep 2008
Vehicle: 1975 450SL
Quoted: 15 Post(s)
You might want to go over to the 107 forum, there's a lot of people there that have a lot of experience. They can help a lot.
A lot of very dedicated people.
RadioTek is offline
    20 years of road safety 420 SE Off-Topic 7 12-04-2010 10:46 AM
    450 SL - best model years Mike Kremers R/C107 SL/SLC Class 8 06-12-2010 08:42 PM
    200 miles off road, 450 miles on road, 31 hours ML430-OFFROAD W163 M-Class 14 07-25-2007 12:52 PM
    Quite possible my last road trip for many years Mercedes SL(ut) W210 E-Class 6 09-30-2006 05:12 PM
    '76 450 SL - Garaged for Several Years BeachRat R/C107 SL/SLC Class 13 07-31-2005 03:25 PM
