1978 280CE timing, valve and ignition - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 04-01-2011, 11:49 AM Thread Starter
Date registered: Jun 2004
Greetings all,
I had either a blown head gasket or a cracked head on my 1978 280ce. I replaced it with a head from a good 1977 280SE engine which was in very good shape and supposedly identical. Along with it I used the 77's cams, camboxes etc. The only difference I could find through research is that the head bolts are longer. I used them as well. The original problem is repaired but my ignition timing is waaaay off. The valve timing is spot right on as well as the ignition but to get the car to run just about correctly I had to advance my ignition like thirty degrees. The compression is fine, I am thinking of using the 77's distributor but doubt if that will help. I would really like to know why I had to advance it so much. Any help and thoughts with this are greatly appreciated.
Bob Piccinini is offline
    70 250C valve and ignition timing specs 126 fan Vintage Mercedes-Benz 19 04-11-2014 06:10 PM
    WTB: 1978 280CE Ignition Control Module Squabble For Sale/Wanted/Trade/Giveaway 0 07-05-2010 08:12 AM
    1978 280ce katkos Vintage Mercedes-Benz 1 05-17-2010 07:00 AM
    1978 280ce katkos General Mercedes-Benz 1 05-15-2010 06:29 AM
    1978 280ce katkos General Mercedes-Benz 0 05-15-2010 05:45 AM
