Weird power steering reservoir leak n 76' 240d - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 03-28-2011, 08:56 AM Thread Starter
Date registered: Jan 2011
Question Weird power steering reservoir leak n 76' 240d
Hey folks,
My power steering reservoir is leaking terribly from under the wing nut that holds the cap on. Anyone have any experience with this issue? I placed a rubber washer with a metal washer on top under the wing nut and clamped it down. This slowed it down, but it's not resolved the problem.
Any info on this issue is appreciated!
Jacob
Portland, Maine
roberson81 is offline
post #2 of 3 (permalink) Old 03-28-2011, 10:36 AM
Witek_M's Avatar
Date registered: Sep 2008
Quoted: 97 Post(s)
Originally Posted by roberson81 View Post
Hey folks,
Jacob
Portland, Maine
Make sure filter is installed correctly. Is fluid clear? Run it with cap off. There should be very little turbulence.
1972 280SEL 4.5
1999 ML320
2000 E320
Witek_M is offline
post #3 of 3 (permalink) Old 03-29-2011, 09:24 AM
Date registered: Jul 2009
Vehicle: 1964 Mercedes 220Sb
Usually, There's air caught in the power steering system. Does your power steering work correctly?
If not it is air causing the fluid to spray and gurgle in the reservoir, the system needs bled via a bleeder on the steering gear.
The air got into the system some how and that should be investigated as well.
Stop blaming the cap before you break it, it doesn't need to be tight just snug, the cap serves as more of a splash guard for bumps than anything else.
tgikal is offline
    Steering Fluid Reservoir Leak ML430 1999 DETANE W163 M-Class 24 08-05-2013 05:54 PM
    W108 Power Steering Reservoir Leak tecrekka Vintage Mercedes-Benz 6 11-05-2010 07:45 PM
    power steering reservoir leak Bruce Tews R/C107 SL/SLC Class 6 09-08-2010 07:46 PM
    Leak Power Steering Reservoir [Photos Included!] Checkit13 W163 M-Class 12 12-30-2009 10:56 AM
    ML 430 power steering leak, from hose not reservoir wjbarton W163 M-Class 11 01-25-2008 11:39 AM
