Diesel fuel used for engine flushing, ok? - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 03-22-2011, 08:46 PM Thread Starter
Date registered: Dec 2009
Vehicle: 1976 300D
Quoted: 2 Post(s)
Send a message via Yahoo to amarbenj
a mechanic told me of the feasibility of using diesel fuel for flushing 300D diesel engine before change oil...This idea is really economical than using commercial oil for flushing..is it ok? any possible danger on the engine? please help. thanks.
amarbenj is offline
post #2 of 5 (permalink) Old 03-22-2011, 11:19 PM
Govert70227's Avatar
Date registered: Oct 2009
Vehicle: 2000 VW Golf Variant
I wouldn't recommend it. Just change the engine oil and filter regularly.
Govert70227 is offline
post #3 of 5 (permalink) Old 03-23-2011, 03:30 AM
Date registered: Mar 2011
Vehicle: 1966 W108 250S
Diesel fuel does not lubricate, so if things go wrong, you kill the engine... not quite a typically economical outcome
What is the reason for being concerned about flushing the engine?
Sjak is offline
post #4 of 5 (permalink) Old 03-23-2011, 03:33 AM
TimmahW123's Avatar
Date registered: Aug 2009
Vehicle: 1991 Mercedes Benz 300D 2.5T, 270,000 miles & counting
Quoted: 30 Post(s)
Absolutely not. Diesel is a solvent. Not only will it eat your seals, but it's not a lubricant. Simply put.. if you mess up it is akin to having water in the oil or diesel in your glass of orange juice.. its nawt fun
TimmahW123 is offline
post #5 of 5 (permalink) Old 03-23-2011, 08:06 AM
The "sub-pan" is made for this purpose, remove it and physically clean it. check the oil pump intake screen too.
For the cost of time and a sub-pan gasket. it is the only way.
If you really want to, you can remove the valve cover and clean from the top to the bottom. I have done solvents and finish flushed with water. Yes through the motor, getting all the pooled oil from the valve area including the oil in the hex bolts.
After water flush spray with WD40 this is what is it good for.
Allow to dry for a few days before re-filling.
Warm-up the motor and have clean oil.
Brian O
bostosh is offline
    124: diesel fuel put into petrol engine.. HELP! chuch124 W124 E,CE,D,TD Class 2 01-14-2011 07:45 AM
    Run engine with diesel fuel? amarbenj Vintage Mercedes-Benz 9 07-05-2010 06:34 AM
    diesel fuel additives cause hotter engine? n23ova W123 E,CE,D,CD,TD,TE Class 13 02-01-2009 04:19 PM
    Flushing Fuel Tank Rajinder_1 R129 SL-Class 1 07-14-2006 08:54 AM
    engine flushing StigHelmer W126 S,SE,SEC,SEL,SD,SDL Class 2 04-29-2005 09:53 PM
