ATF for w115 manual tranny - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 03-20-2011, 10:53 PM Thread Starter
Date registered: Jun 2009
I've been told that the ideal transmission fluid for MB manual transmissions, even older models like pontons and finnies, is ATF. Is this information correct? My w115 200d is due for an oil change and I would like to change all other fluids as well. Will appreciate any advice. Thanks!
ijiwaru is offline
post #2 of 5 (permalink) Old 03-21-2011, 12:13 AM
Date registered: Jul 2004
Vehicle: 1971 280SE 3.5 Coupe
Quoted: 8 Post(s)
Yes manual transmissions require ATF. Red Line manufactures a ATF sutable for manual transmissions that require ATF. This is what I use in mine:
Red Line Synthetic Oil - Automatic Transmission Fluids - D4 ATF
Tony
280SE 3.5 Coupe
Stick shift
3.27 Axle
5.6 Iron block build in progress
3.5 Tony is offline
post #3 of 5 (permalink) Old 03-21-2011, 02:14 AM
Govert70227's Avatar
Date registered: Oct 2009
Vehicle: 2000 VW Golf Variant
Quoted: 4 Post(s)
Sometimes a slightly heavier manual gear box oil is used for transmissions that are on the way out, but ATF works fine in most cases.
Govert70227 is offline
post #4 of 5 (permalink) Old 03-21-2011, 05:05 AM Thread Starter
Thanks for the inputs! Does the same hold true for newer MBs with manual transmissions like the w124 and w210?
ijiwaru is offline
post #5 of 5 (permalink) Old 03-21-2011, 05:35 AM
Quoted: 4 Post(s)
ATF is still prescribed for the W124 (at least the early ones), the W210 probably takes special manual gear box oil, it will be in the WIS.
    atf from tranny gies to radiator and caused the water to mix in the tranny dranrebdy W210 E-Class 4 01-01-2011 05:04 AM
    ATF ok to use in getrag manual tranny? masterdog W201 190-Class 2 09-17-2009 02:49 PM
    W115 240D CD service manual 24td Vintage Mercedes-Benz 0 04-13-2009 01:34 PM
    This ATF says it meets 236.10 (ie for 722.6 tranny) stumo W163 M-Class 10 10-17-2008 02:56 AM
    W115 Factory shop manual??? americanflyer302 Vintage Mercedes-Benz 1 03-21-2007 02:37 AM
