W111 fuel air ratio Mixture adjustment. - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 03-17-2011, 09:00 PM Thread Starter
trazique's Avatar
Date registered: May 2008
Vehicle: '99 CLK430, 62 220se, 64 220se, 65 220se, 66250se, 85 380sl, 90 190E 2.6
Quoted: 57 Post(s)
Send a message via Skype™ to trazique
Can the fuel air ratio mixture be adjusted on a W111?
trazique is offline
post #2 of 7 (permalink) Old 03-17-2011, 09:38 PM
idle mixture can be, running is controlled internally
Brian O
bostosh is offline
post #3 of 7 (permalink) Old 03-17-2011, 09:55 PM Thread Starter
trazique's Avatar
Quoted: 57 Post(s)
So I just put this thing together hoping to get it done for my birthday end of this month. Wot do you think??
Im running it, its idling rough and exhaust smells rather rich.
Name:	2011-03-09 19.25.19.jpg
trazique is offline
post #4 of 7 (permalink) Old 03-18-2011, 10:18 AM
Date registered: Jul 2004
Vehicle: 1971 280SE 3.5 Coupe
Quoted: 8 Post(s)
It seems that most early FI systems whether mechanical or electronic ran rich. I wonder if the engineers designed them to err on the rich side to insure the engine never ran lean since there is no feedback.
Tony
280SE 3.5 Coupe
Stick shift
3.27 Axle
5.6 Iron block build in progress
3.5 Tony is offline
post #5 of 7 (permalink) Old 03-18-2011, 10:50 AM
Check the rods activating the throttle and MFI pump for correct synchronization. the ball ends can get sloppy and worn, I've packed them with aluminum foil to tighten temporarily.
Check the spark plugs for correct color rich/lean.
You should get a crisp throttle response.
cold start valve can dribble onto the a/f mix.
I think the w113 website has the instructions to set-up the MFI correctly.
Brian O
bostosh is offline
post #6 of 7 (permalink) Old 03-31-2011, 08:45 PM Thread Starter
trazique's Avatar
Quoted: 57 Post(s)
Thanks Guys your input was very very helpful.
trazique is offline
post #7 of 7 (permalink) Old 04-06-2011, 10:07 AM
wbain's Avatar
Date registered: Dec 2003
Linkage Tour Link :)
Linkage Tour
wbain is offline
    Air/Fuel Mixture adjustment HELP!!! blaydrunner W201 190-Class 10 01-06-2016 08:18 AM
    230E Air/Fuel Mixture Adjustment 4484 W124 E,CE,D,TD Class 5 09-07-2009 09:30 PM
    Air/Fuel Mixture Adjustment Springbok93 W124 E,CE,D,TD Class 4 07-15-2009 04:57 AM
    Air/Fuel mixture adjustment on a 95 E320. soundquest W124 E,CE,D,TD Class 6 05-03-2009 09:22 PM
    adjusting fuel air mixture ratio william.wood W126 S,SE,SEC,SEL,SD,SDL Class 5 11-11-2005 01:25 PM
