Air in my Power Steering - 69 W114 - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 03-17-2011, 11:39 AM Thread Starter
Dan Knauss's Avatar
Date registered: Feb 2011
Vehicle: 1969 W114 250 /8
Hi, I've apparently got air in my power steering system, as of late there's been some groaning and on inspection the reservoir fluid is foamed up.
I understand this can be solved by bleeding the system and refilling with ATF.
I have a chilton's repair guide but the pics are not the best so I would really appreciate a tip RE finding the right spot to bleed from and the best way to go about it. Help on finding the spot, especially with a picture to work from, would be ideal for this noob.
Other tips from those who have done this procedure would be great too. For example, on newer systems it is advised to work the wheels from side to side with the front end lifted to help work the air out of the system. Should I include that in the procedure?
Thanks very much for your responses,
PS - I know that the ultimate cause of the air in the system is a probably a leak, and I intend to source and correct that eventually. For now, I would like to get the air out and go from there to see if I can limp it along until I save the $$ to do the permanent fix.
1969 W114 250 /8
Dan Knauss is offline
post #2 of 5 (permalink) Old 03-17-2011, 06:07 PM
Govert70227's Avatar
Date registered: Oct 2009
Vehicle: 2000 VW Golf Variant
Quoted: 4 Post(s)
too soon.
Govert70227 is offline
post #3 of 5 (permalink) Old 03-17-2011, 06:19 PM
Date registered: Jul 2009
Vehicle: 1964 Mercedes 220Sb
There's a bleeder on the steering gear, probably on the top close to the steering slack screw, might have a rubber cap over it, will look like a large brake bleeder screw.
-Open the bleeder up, attach hose to it, so it stays on!
-Start the car and turn the wheel while adding new fluid (best with two people).
-When dirty/foamy fluid stops coming out, turning the wheel both ways, tighten the bleeder back.
tgikal is offline
post #4 of 5 (permalink) Old 03-17-2011, 08:44 PM
Run the clear plastic line (you will get at the hardware store) from the bleeder into the power steering reservoir and (at idle) watch until the bubbles clear. crack the bleeder open to bleed and finger tighten or loosen while running to control the flow.
or dump the old into a jar, keep the res. filled. do not allow it to suck air.
Brian O
bostosh is offline
post #5 of 5 (permalink) Old 03-18-2011, 05:22 AM
Probably should mention I went through the same thing:
I bled it last year and it has sat all winter, drove it three days ago and the power steering still works fine, so if mine has a leak its VERY slow. Personally I think the previous owner tried to change the fluid, let it get air in it and didn't realize there was a bleeder. But I don't know your situation...
tgikal is offline
    Prime power steering pump that's full of air?? FireFox31 W210 E-Class 2 07-10-2010 08:34 PM
    How do you know when there is air in the power steering? my04mll350 W163 M-Class 10 01-16-2010 06:18 AM
    MB Instructions on how to fill and remove air from the Power Steering System AC_ML W163 M-Class 0 10-06-2009 08:43 AM
    Power Steering: Changed the Reservoir, Bled System of Air and.....Now.... FAR888 W163 M-Class 30 01-18-2009 02:14 AM
    Anyone know how to bleed air out of power steering? surfjones W126 S,SE,SEC,SEL,SD,SDL Class 6 03-27-2007 10:47 PM
