My W108 restoration :) - Page 4 - Mercedes-Benz Forum
post #31 of 42 (permalink) Old 04-06-2011, 07:31 AM
Vehicle: Unimog 1700L (1981), w460 300gd (1981), w108 280s (1966)
It's a spam, so just ignore it.
W108 280s (1966)
W460 300GD (1986)
Unimog 1700L 1980
gclass is offline
post #32 of 42 (permalink) Old 05-08-2011, 03:25 PM
Date registered: Oct 2008
Vehicle: 13 Fiat 500, 06 Suzuki, 04 MB CLK500C, 02 LR DII, 90 MB 560SEL, 90 MB 560 SEC.
Quoted: 5 Post(s)
I am anxiously awaiting each post on this project. If you are able to check off each box on your list, this will be one amazing W108. Good luck with the project.
1990 560 SEL (Hans) & 1990 560 SEC (Hugo), both built in 08/89 in 702 over 265. (My Fraternal Twins)
1987 560 SEC AMG in 122 Pearl Grey Metallic.
1994 S420 (Gunter), in 199 Blauschwartz; (Traded in on W220).
2001 S600L (Hannah), in 753 Tectite Gray Metallic; (Gone in 08/12).
1979 300 CD in robins egg blue; (Gone in 11/12).
DanielSL is offline
post #33 of 42 (permalink) Old 05-09-2011, 01:30 AM Thread Starter
Date registered: Mar 2011
Vehicle: 1967 250SE
Dash
This is my gorgeous chocolate brown suede dash : )
springerwmt is offline
post #34 of 42 (permalink) Old 05-09-2011, 01:44 AM Thread Starter
Vehicle: 1967 250SE
Wood Trim
This is the wood trim from my dash, I've stripped it and sanded it back but now I'm not sure what I want to do with it... re-veneer or start from scratch... or if I decide to revamp the stuff that I've got, I'll have to stain it all because time has faded it and it's all different colours.... decisions, decisions!
post #35 of 42 (permalink) Old 05-09-2011, 02:07 AM
Vehicle: 1966 W108 250S
WOW, that dashpanel looks really nice, looks like a pro did it! How did you apply the suede to it?
Sjak is offline
post #36 of 42 (permalink) Old 05-21-2011, 03:21 AM
Date registered: May 2011
Vehicle: 1964 Mercedes 190c, 1968 Mercedes 230S, 1979 Mercedes 230, 1961 Auto Union 1000S
Looking great so far! Keep up the good work!
El Stiemo is offline
post #37 of 42 (permalink) Old 05-21-2011, 05:22 AM Thread Starter
Vehicle: 1967 250SE
With a LOT of patience, and Sellys Quik Grip : )
I brushed the adhesive on a little bit at a time and smoothed the suede over the top to keep it all flat without creases and stuff. And if you put a bit much adhesive on, or didn't wait for it to go off enough before smoothing the suede over, it'd get a wet patch and be ruined. It took like 3 attempts : )
post #38 of 42 (permalink) Old 05-21-2011, 05:42 AM Thread Starter
Vehicle: 1967 250SE
Update
Just a little progress update... pics tomorrow : )
So, today we repaired the rear guards and sill panels, and applied spray putty to the rear guards. Get to start blocking out tomorrow, yay!
Oh, and with the steering wheel, I've decided not to have it plain old boring old white! Stay tuned : )
post #39 of 42 (permalink) Old 05-21-2011, 06:34 AM
re: steering wheel
I've got the ivory one in the litle fin and a black one in the big fin. The black wheel is fine, uncracked, and the cushion around the emblem is fine as well. With the ivory one, that is quite cracked, unfortunately, and the cushion was completely ruined. What I decided on there is to have a replacement 'cushion' made from the same wood that I've had put on the dash (rosewood), and then use that as the centre piece. The back of this circular wooden block still needs grinding out for the locknut to fit in there and the chrome ring over the outside...
Not too sure yet about the wheel itself, the pitted one in the Auto Union I just sanded down and sprayed it in Hammerite dark grey and left the interior Ivory badge. Looks OK. But that wheel is Bakelit, where the Merc one is plastic.
If I can get a solid enough substrate built up around the wheel to cover the cracks and pitting, this can then be sanded for spraying... Possibly body colour (that car is ivory grey).
Do the wheel in body colour, should look nice or cover in suede like the dash panel?
Look forward to seeing your progress!
post #40 of 42 (permalink) Old 05-25-2011, 12:50 AM
50$84sd's Avatar
Date registered: Oct 2009
Vehicle: 1965 220se w111 *******1984 300sd w126 *******1991 350sd w126
Good looking resto so far and excellent interior work, you def. need patience with the detail involved. Later.
50$84sd is offline
    Restoration? MercedesForever W201 190-Class 4 08-19-2010 09:01 PM
    '89 2.6 Restoration raed_jan W201 190-Class 15 06-17-2009 04:50 PM
    Restoration eldorado1954 W126 S,SE,SEC,SEL,SD,SDL Class 13 05-08-2009 04:55 PM
    New W108 Owner...Source for W108 Door and Window Seals? LaterApex Vintage Mercedes-Benz 5 03-24-2008 12:51 PM
    W108 Restoration GreenlandW108 Vintage Mercedes-Benz 6 07-24-2006 03:47 AM
