My W108 restoration :) - Page 3 - Mercedes-Benz Forum
post #21 of 42 (permalink) Old 03-26-2011, 06:24 PM
DanW114's Avatar
Date registered: Jan 2011
chocolate brown and red. You're gunna feel like eating a cherry ripe every time u drive it :P
DanW114 is offline
post #22 of 42 (permalink) Old 03-26-2011, 07:59 PM
euroamg's Avatar
Date registered: Oct 2004
Quoted: 36 Post(s)
Talking
Zinc coat the bare metal to prevent rust. Not sure if you use them over there.. Looking forward to seeing more progress on the car.. Cheers :-)
Wanted 1 15" ARC & 1 15" Centra Bundts wheels
'76 300D '84 300DT
'86 300SDL '91 300D 2.5 Turbo
'92 300E Sportline '92 400E
Euro spec '88 560SEC '89 560SEL
'90 300E-24 '82 230CE
'88 250d 5 speed '88 300d 5 speed
' 88 300te 5 speed X2
euroamg is offline
post #23 of 42 (permalink) Old 03-28-2011, 01:08 PM
Gustav's Avatar
Date registered: Feb 2007
Vehicle: 1968 250SE
Rear End
Originally Posted by springerwmt View Post
Plans include:
*Engine conversion to a 2JZ with a big single turbo, powerglide with transbrake and 9 inches of Ford's finest
Hi - I would love to hear how you are planning on installing a Ford 9" rear axle and what axle width you are going with.
I am facing a similar issue as my new engine has more than double the original power and the goal is to bump the engine's output to around 500hp, which would turn the Mercedes rear axle into metal salad.
Nice progress on your car. Keep it coming
Gustav is offline
post #24 of 42 (permalink) Old 03-29-2011, 10:47 PM
Date registered: Jun 2004
Quoted: 17 Post(s)
Smile I dont like 9"inch diffs...
I dont think the ride quality will be affected too much as it will be set up very soft. some model falcons came with discs so no problems there. I dont think the old merc diff would be able to handle the abuse I intend to give it.
few more pics
I have the front guards, bonnet and doors stripped and they have very little rust in them, few repairs to do but i am happy
Your factory rear end will more than handle the jap engines torque and to mount the Ford 9" is , As Al rightly points out. a step backwards. The 9" diffs suck power because of the 54 year old design (yes they were designed that long ago) and you will end up with an ill handling pig. A safe in a wheel barrow is how a mate here in brisbane describes the handling of his W108 with Ford 9" diff.
A lot of mystique and BS has grown over the years regarding the Ford axle and because you are in OZ you could actually get a commodore (and cortina 6,Valiant, Falcon, Sigma ,Centura etc etc ) Borgwarner rear end as cheap as chips with dozens of different ratios and LSD configurations .They are still used in the latest HSV's .
Besides the loss of independent rear end you will be adding a huge amount of extra unsprung weight which is a sure way to kill handling. (ever tried picking up the pumpkin from a ford diff?)
Sure Falcons have them but they are crappy cars ,you have a Mercedes and fitting ford parts is wrong LOL!.
Now,to issue of power sapping,the Ford 9" is known for this and bvecause you are using an engine designed for a smaller lighter jap car you are going to be struggling to get real performance.
Why not use the merc back end until (if) it blows up?
The Mercedes 6.3 has the same diff (higher ratio and LSD) and several hundred horsepower and foot pounds of torque doesn't break them.
I recently did a Merc V8 with 300KW into a finny which is running a stock rear and it's fine . lots of abuse in the last 3 months and no sign of trouble. You should look at the axles,they are bigger than the 9" axles.. :-)
You should go over to the ozbenz site,plenty of performance upgrades going on there plus contacts with lots of spares for W108's...including me,I have tonnes of them.
mercmad6.3 is offline
post #25 of 42 (permalink) Old 04-01-2011, 05:46 AM Thread Starter
Date registered: Mar 2011
Vehicle: 1967 250SE
Steering Wheel Mini Make-Over...So far...
So, horn pad is finished, now i've decided to give the actual wheel a bit of a make over. Pics to come
ID:	366892   Click image for larger version
springerwmt is offline
post #26 of 42 (permalink) Old 04-01-2011, 05:55 AM Thread Starter
Vehicle: 1967 250SE
This is a small sample of what my dear Merckie can look forward to
post #27 of 42 (permalink) Old 04-02-2011, 09:14 PM Thread Starter
Vehicle: 1967 250SE
Carpet
Does anyone know how many pieces are in the carpet set?
I took 8 pieces out... just hoping that none are missing...
I bought a roll of gorgeous white carpet to re-do mine, just cut all the mats out, then off to the upholster to get the edging done
post #28 of 42 (permalink) Old 04-02-2011, 09:21 PM
Date registered: Dec 2004
Vehicle: 1972 280CE
Quoted: 115 Post(s)
i'm having my seats recovered at a local place. The guy currently has a Cadillac coupe deville in there that he just redid with yellow and white seat covers and door panels and white carpet. I took one look at those carpets and thought that whoever owns that car had better take their shoes off when they get in.
With best regards
Al
Check out the W114, W115 /8 enthusiast forum http://www.stroke8.org
My 280SL restoration
alabbasi is offline
post #29 of 42 (permalink) Old 04-04-2011, 01:48 PM
Date registered: Apr 2011
I have been known to change my mind... I started with wanting to paint her matte black, and went from there to gloss black, to gun metal, to pearl white, back to gun metal,and they have very little rust in them, few repairs to do but i am happy
M.afaqanjum228 is offline
post #30 of 42 (permalink) Old 04-06-2011, 03:42 AM Thread Starter
Vehicle: 1967 250SE
wtf
Restoration? MercedesForever W201 190-Class 4 08-19-2010 09:01 PM
'89 2.6 Restoration raed_jan W201 190-Class 15 06-17-2009 04:50 PM
Restoration eldorado1954 W126 S,SE,SEC,SEL,SD,SDL Class 13 05-08-2009 04:55 PM
New W108 Owner...Source for W108 Door and Window Seals? LaterApex Vintage Mercedes-Benz 5 03-24-2008 12:51 PM
W108 Restoration GreenlandW108 Vintage Mercedes-Benz 6 07-24-2006 03:47 AM
