w115 power steering pump - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 03-09-2011, 10:07 PM Thread Starter
Date registered: Jun 2009
I just wanted to ask if the power steering pump of a w123 is the same as those in a w115. I've been looking for a power steering pump for my 1969 model 200D and a friend's mechanic told me that I could use a w123 pump since the same was used for both the w115 and the w123. Is this correct?
ijiwaru is offline
post #2 of 9 (permalink) Old 03-10-2011, 01:36 AM
Govert70227's Avatar
Date registered: Oct 2009
Vehicle: 2000 VW Golf Variant
Quoted: 4 Post(s)
It is a different pump. The W123 pump has an inbuilt reservoir, the W115 has a seperate reservoir. It is also located on a different spot.
If you are handy with iron, you might be able to fit a W123 pump on a W115. The problem is not only the pump, but also the correct bracket (which doesn't break or come loose).
Govert70227 is offline
post #3 of 9 (permalink) Old 03-10-2011, 04:17 PM Thread Starter
Thanks for the information. I will resume my search for a w115 power steering pump then. Cheers!
ijiwaru is offline
post #4 of 9 (permalink) Old 03-14-2011, 10:16 PM
barnumlives's Avatar
Date registered: Aug 2009
Vehicle: W114/115 220d (1972) [sold] and W123 300tdt (1984) and two L406DG's (1967)
W115 power steering pump x2
just noticed you're searching for a pump for your '69 200d. my 1972 220d never was never equipped with power steering but both my parts cars have it!
one is a 1970 220d and the other a 1972 220d. never having started or driven either one i can't speak to the pumps' condition, but if you are interested in one of these we can work up a price then work out the particulars.
where are you located?
barnumlives is offline
post #5 of 9 (permalink) Old 03-14-2011, 11:36 PM Thread Starter
Thanks, barnumlives! My 200d is not originally equipped with power steering as well. I am installing power steering to make it easier to drive. I already have the steering gear. I am still looking for a pump and a pulley. I am in Manila, the Philippines. Where are you located?
ijiwaru is offline
post #6 of 9 (permalink) Old 03-15-2011, 08:09 AM
220d pump/pulley
i am located in the USA... 43615 zipcode which is in the state of Ohio.
post #7 of 9 (permalink) Old 06-16-2015, 03:28 PM
Date registered: Jun 2015
I need help Im 16 and I have a 1972 220d as my first car and my power steering wasn't woriking so I go looking for the pump and I find out the belt is missing but I can't find were the belt is supposed to go can someone help
Bryan99 is offline
post #8 of 9 (permalink) Old 06-17-2015, 06:08 AM
rumb's Avatar
Date registered: Oct 2012
Quoted: 500 Post(s)
Hi Bryan,
Here is a picture of your pump area. there should be a belt from the crank pulley to the PS pump pulley.
Please complete you profile so we know where you live.
here is how to adjust your belts
http://www.benzworld.org/forums/vint...oose-240d.html
rumb is offline
post #9 of 9 (permalink) Old 06-20-2015, 03:26 AM
Date registered: Sep 2012
Vehicle: 300sel W109, 280S 70 , 220s 62. 230 66. Lancia Flavia 63.Pininfarina
Quoted: 59 Post(s)
Is there a place that can rebuild a RHD steering box? Have a spare one one with loads of play in it.
adler is offline
    Power steering on W115..re-inforcement. Eirik 400 SE Vintage Mercedes-Benz 3 09-19-2012 07:24 AM
    FS: 2007 CL550 power steering pump (ABC pump) Streetglower For Sale/Wanted/Trade/Giveaway 2 11-13-2011 05:54 PM
    w115 76 300d power steering belt slipping? euromarko Vintage Mercedes-Benz 3 08-17-2010 08:03 AM
    W115 floorshift, conversion to Power steering Eirik 400 SE Vintage Mercedes-Benz 3 04-21-2008 01:35 PM
    92 400E Power steering pump and water pump, need advice kanio W124 E,CE,D,TD Class 5 03-19-2007 05:58 PM
