What oil do i use for MB 220SEb (W111). - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 03-08-2011, 02:48 AM Thread Starter
Date registered: Feb 2011
Vehicle: MB W111 220SEb (1964), Mini Moke (1970), Mini Cooper (1975).
Can some good fellow tell me what kind of oils uses my Mercedes 220SEb?
Transmision, engine, gearbox, brakes, steering,etc.
For the engine, i have been told that it is best a semisyntetic 20w50.
This engine goes at 4000rpm at 120kph, so in summer gets quite hot. Does oil type help to keep it cooler?. If it does, what type?.
Thank you.
purdey is offline
post #2 of 9 (permalink) Old 03-08-2011, 06:32 AM
Date registered: Jan 2009
Vehicle: 99 ML 430; 61 220Sb
i will eagerly follow this thread.... I need to replace all fluids in my W111 as well
BlinduL is online now
post #3 of 9 (permalink) Old 03-08-2011, 10:11 AM
Emre-K's Avatar
Date registered: Jun 2009
Vehicle: '87 190E 2.3-16
These classic Benz engines seem to run best on conventional (or semi-synthetic) oils in 20W-50 that are high in ZDDP content. Personally, I've had great experiences with Kendall GT-1 and Brad Penn PG-1 oils. If the engine is really burning a ton of oil, I'll add some Lucas HD Oil Stabilizer (about 15-20% by volume).
Having said that, lots of guys swear by diesel formulations for these older engines. Shell Rotella T6 5W-40, Mobil Delvac 1300 Super 15W-40, and Chevron Delo 400 Multigrade 15W-40 are all very popular with classic Benz owners. At least one independent Mercedes repair shop I know uses Mobil Delvac almost exclusively.
1987 W201 190E 2.3-16: Vintage racer
1990 C124 300CE coupe: Daily Driver
1991 Peugeot 405 Mi 16: Weekend Toy
Emre-K is offline
post #4 of 9 (permalink) Old 03-08-2011, 10:39 AM
Date registered: Mar 2011
Vehicle: 1966 W108 250S
The Brad Penn is a great oil!
Sjak is offline
post #5 of 9 (permalink) Old 03-09-2011, 01:18 PM
CRJ9Driver's Avatar
Date registered: Nov 2009
Vehicle: 1956 Buick Century Coupe, 1937 Pontiac Business Coupe
This is going to be fun
CRJ9Driver is offline
post #6 of 9 (permalink) Old 03-09-2011, 07:52 PM
Date registered: Jul 2010
Vehicle: 1972 Mercedes 250C
Sorry to steal the tread...have a W114 and also thinking about what motor oil to use. Previous poster recommended diesel engine oil...is that a good choice for the M130 engine? Thanks for any info.
Dylan1471 is offline
post #7 of 9 (permalink) Old 03-09-2011, 09:56 PM
trazique's Avatar
Date registered: May 2008
Vehicle: '95 E320 Wagon '99 CLK430, 62 220se, 64 220se, 65 220se, 66250se, 85 380sl, 90 190E 2.6
Quoted: 57 Post(s)
Send a message via Skype™ to trazique
What about the fuel injector pump? what kind of oil should be used in it?
trazique is offline
post #8 of 9 (permalink) Old 03-11-2011, 02:59 AM Thread Starter
I think that the injection pump uses the same oil as the engine.
Thank you Emre-k for your info. I have bought 20w50 and an oil additive for my W111. I hope that with this one stops consuming oil and keeps the temperatura lower in the summer.
In an specialised MB classic garage they told me that in extreme oil consuming cases they have used Shell 10w60. With this oil they avoided opening the engine of an 1960´s MB they had for restoration. It is a quite expensive oil.
purdey is offline
post #9 of 9 (permalink) Old 03-11-2011, 03:16 AM
If oil consumption is an issue, you may want to check valve seals, piston rings and also valvecover & pan gaskets.
If cooling is an issue, check and rebuild or replace the radiator. Check ignition timing. Check your fan and fan clutch.
There are also some cooling additives (e.g. Wetter Wett) which can give you a small edge.
Sjak is offline
    Sold my 61 W111 220SEb Coupe today alydon Vintage Mercedes-Benz 2 11-24-2009 03:46 AM
    W111 220SEb - Can't Remove Oil Canister soldbydon Vintage Mercedes-Benz 6 05-20-2009 09:00 AM
    oil type and filter for 64 w111 seb? sluggoG Vintage Mercedes-Benz 3 02-20-2008 07:42 PM
    W111 220SEb Coupe Show car on Ebay alydon Vintage Mercedes-Benz 4 09-03-2007 02:06 AM
    '61 W111 220SEb coupe restoration heckflosse_uk Vintage Mercedes-Benz 20 03-07-2006 01:31 AM
