Help with Duraterm glow plug update 1974 240D - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 03-06-2011, 08:11 PM Thread Starter
Date registered: Mar 2011
I am installing the Duraterm glow plug update for a 4 cylinder 240D. I was wonder what amp fuse to run from 8 on the glow time controller. I have a 30amp fuse and when I pull the lever to start the glow plug heatup, the glow plug lamp indicator will light for about 2 seconds and then the 30 amp fuse blows. I have a 50amp fuse from 9 to the first glow plug. Do I need a 50 for terminal 8 to the pos on the battery.
Thanks
1974benzman is offline
post #2 of 3 (permalink) Old 03-07-2011, 04:17 PM Thread Starter
does anyone know the answer to what amp fuse.
post #3 of 3 (permalink) Old 03-11-2011, 04:23 AM
Witek_M's Avatar
Date registered: Sep 2008
Quoted: 116 Post(s)
Thanks
Those glow plugs are not standard on MB. Kit comes with absolutely idiotic instructions and no technical data.
Find out what single glow plug draws and multiply x4. I would say ~80A slow blow. Fuse needs to be as close to battery as possible.
1972 280SEL 4.5
1999 ML320
2000 E320
Witek_M is offline
    Hooking up the Bosch Duraterm Glow Plug Kit fantasygoat W123 E,CE,D,CD,TD,TE Class 16 03-13-2011 05:09 PM
    Where can I get Glow Plug bushings for a 240d? rathersmart W123 E,CE,D,CD,TD,TE Class 20 03-02-2011 09:01 AM
    1974 206D Glow Plug Questions studebakerman2001 Vintage Mercedes-Benz 0 04-06-2010 10:45 AM
    1974 240D glow plugs onefew Vintage Mercedes-Benz 4 01-20-2010 08:09 AM
    Bosch Duraterm glow plug upgrade Necrosavant Vintage Mercedes-Benz 5 03-19-2009 03:52 PM
